Sony kdl-32s2000 inverter/transformer
  • high-tech
    • Sep 2010
    • 197
    Hi all, I found a blown fuse and a shorted primary winding on 1 of the inverter transformers. I can't find a source for this type of coil.
    Anybody know where I can get 1? I don't want to buy a used board, they start at 75 and go up, ouch!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Sony kdl-32s2000 inverter/transformer
    Your photo is way too small to make out any identifying part numbers on the transformers, but try the usual ebay auctions.
    Maybe also try
    http://www.lcdparts.net/T.aspx
    --- begin sig file ---
    --- end sig file ---
    • Village Electronics
      OldPro
      • 118
      That looks like a common inverter board. You did not post numbers. I have lots of them. See if my picture is the same as yours.
      • high-tech
        • Sep 2010
        • 197
        Yes that is the exact inverter board I have, so I looked around trying to find a replacement transformer and no luck so far.
        • caseyjay_48
          Sony KDL-46BX450 Inverter Troubleshoot Logic
          by caseyjay_48
          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
          09-23-2022, 08:08 PM
        • denisten
          Sony STR-DB870QS standby transformer
          by denisten
          Hi everyone, i am a newbie here and i hope i will find the help i need. I have the above mentioned receiver with standby transformer's primary coil damaged. I have searched the net without success to find any tech data about this transformer. I have only the Sony part number1-437-313-11 and TAM Malaysia M0126. I guess i could find replacement for it, but i need to know the secondary coil voltages and VA. It is 220v on the primary. It has 5 pins on the secondary, the outer two are not used and i have 6.5 ohms between pins 2and 4, 3,9 ohms between 2 and 3, and 3,6 ohms between 3 and 4. Can someone...
          04-14-2023, 03:24 AM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • notallbad
          Sony Cmt-cp33md power transformer blown
          by notallbad
          Power transformer has open circuit on the 230v primary side, its tapped for 115v too which is also open so most likely the thermal fuse has blown. It doesnt look like it would be possible to open it up to check the thermal fuse so looking to replace.
          What are peoples thoughts on repair?
          replace the one transformer with 2
          replace like for like, though unlikely to find a direct replacement...
          01-22-2023, 03:47 PM
          Sony CFD-E55 boombox blown line transformer & repair
          by momaka
          Is a mid-2000’s boombox worthless? - I’d say probably yes or at least certainly a candidate for this thread:
          https://www.badcaps.net/forum/showth...post+worthless
          Long story long , my dad picked up a Sony CFD-E55 boombox over a decade ago from the trash room in a condo where we used to live.
          (Note: picture below is of the boombox after the repair.)
          He then put it in a box when we moved places and it sat in the garage for a few years. Eventually, I tested the boombox and found that it worked on batteries, but not on...
          10-03-2020, 01:13 PM
