Technika LCD 26 207 Colour fault on right hand side of screen
+ More Options
Posts
  • Jon Templeman
    • May 2011
    • 16
    As you can see from the pictures, the whites are being displayed as pinks in this section of the screen
    Any help would be greatly appreciated
    TIA
    Jon
    ps Here are a couple of links to videos of the fault
    Technika LCD26 207 Video 1
    http://www.youtube.com/watch?v=y_iNKKjXjDQ
    Technika LCD26 207 Video 2
    http://www.youtube.com/watch?v=IOKr4zYMITE
  • Village Electronics
    OldPro
    • 118
    Re: Technika LCD 26 207 Colour fault on right hand side of screen
    TIA
    Jon
    This is a defective LCD panel.
    • truep
      • Aug 2010
      • 373
      Could also be a defective tcon board or a bad connection between the tcon and the panel.
      It looks like it's in about 1/4 of the screen. Mant TCON boards have 4 connectors going to the panel. I would first check the connections. There is a small tab that runs across the connector that must be popped up to remove the cable (they are delicate). remove the dables and clean the cable bare side GENTLY with a pencil eracer. You might also try replacing the tecon board. The tecon board is usually under a shield at the top of the panel
      • Jon Templeman
        • May 2011
        • 16
        Hello and thanks to you both, Village electronics and truep, for your replies.
        I will have a go at truep's suggestion and update the forum with the results
        Thanks again, best regards,
        Jon
        • Jon Templeman
          • May 2011
          • 16
          Hello Guys,
          I found the TCON board - Pictures attached, correct me if I am wrong - And I am having difficulty removing the cable, any suggestions please?
          The cable that went into the silver connector came out no problem.
          Thanks in advance,
          Jon
          • PlainBill
            • Feb 2009
            • 7034
            Hello Guys,
            Thanks in advance,
            Jon
            This might be a latching connector. One part will lift up, then the cable will slide out. Don't force it!!! Pictures from several angles would help.
            PlainBill
              OldPro
              • 118
              Hello Guys,
              Thanks in advance,
              Jon
              Note the black line across the blue portion of the ribbon cable. This is the insertion depth indicator. Just below that line there is a hinged latch. That will pull up and release the cable.
              Note: In the other picture there is a PC board permanently connected to the LCD panel. There are 4 ribbon cables running from that board to the panel. Imagine a matrix of cells feed by each ribbon to the cells. That matrix is not getting green control signals from the electronics or ribbon that feeds it. It could be the ribbon that has come apart from the panel. It could be a failure of the electronics on the PC board. Neither is repairable and the problem will continue.
              • Jon Templeman
                • May 2011
                • 16
                Village Electronics, you are correct, there is a fault / break in the cable (The one in the red box in the picture) leading to the LCD panel.
                I noticed that when pressing the cable the fault came and went, so done a bodge job and managed to get the TV working again.
                Not perfect but it will do :-)
                Thanks for all the help guys,
                Jon
                http://www.youtube.com/watch?v=AdyCW7_qWZ8
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • c_corr
                  Asus P4C800-E VRM issues
                  by c_corr
                  This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
                  This board uses mext ICs and Mosfets in VRM:
                  - ADP3180 PWM controller - in 3 phase mode
                  - ADP3418 as Modfet drivers
                  - High side Mosfets STD38NH02L (from ST)
                  - Low side Mosfets STD90NH02L
                  Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
                  I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
                  02-08-2025, 11:59 PM
                • Gjackson
                  SMEG induction cooker error EA on both left hand side cooktops
                  by Gjackson
                  I have a SMEG cooktop with a EGO 72.08041.002 power board. The two left hand side cooktops started to slowly fail, sometimes stopping with an EA error (Power board failure according to the manual) after a couple minutes boiling some water and eventually they completely failed and now get an EA error on both of them at all times. Visual inspection of the board went over ok, I checked the IGBT's and rectifiers and they seem fine, what should I look at next as this is the first time I'm fixing an induction cooker, I'm suspecting capacitors in this case, Which ones should I look...
                  07-09-2024, 01:46 PM
