Step by step Troubleshooting your LCD Power Board
  • avonero
    • May 2011
    • 13
    • Guinea
    Lets all share our knowledge on successfully troubleshooted DEAD Power board.
  • avonero
    • May 2011
    • 13
    • Guinea
    Re: Step by step Troubleshooting your LCD Power Board
    Example...
    Amilo LXL 3220W
    it went dead without no standby light. which i had removed its power pack and measure its output voltage to the main picture board and reads normal 5.1/5.2vdc
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      The first step usually starts with posting pictues of your set on Badcaps.net using "Manage Attatchments" on the posting page. These picures would show the set's front side, insides (full set layout of all boards), then each board single close ups.
      The explanation of failure could point towards either of the boards to be bad. There is nothing to suggest ruling out one or the other of the boards, especially because the set is not a major brand name.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
        After all of...
        07-13-2024, 08:14 PM
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
      • Cooperr
        Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
        by Cooperr
        I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
        The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
        10-21-2025, 01:11 PM
