Sharp DV6345S don't turn on
  • tabbiati
    • Jan 2011
    • 6
    My friend old Sharp DV6345S don't want turn on:
    (no screen no audio only a repetute bomp on audio
    from protection circuit ) someone have this experience
    or have schematic?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sharp DV6345S don't turn on
    Service manual is here.
    PlainBill
    • tabbiati
      • Jan 2011
      • 6
      Thank PlainBill; next week i try repair and if it possible i reply here for all...
      • tabbiati
        • Jan 2011
        • 6
        ALL OK,
        change 2SD1546 traco with BU508 isolated: now work....
        • thetonywarren
          Sharp 4P-B43EJ2U wont turn on
          by thetonywarren
          Sharp TV/Display, wont turn on. Brand new, used for maybe 30 minutes. Possibly heard pop then set went dead. I took a look at the boards, no visual damage to boards. The led power indicator is ON, remote will not turn on. I verified that backlights do come on when powered with separate power supply/LED tester. I also...
          10-01-2025, 09:30 AM
        • JunkmanJimbo
          Sharp lc-55p6000u won't turn on
          by JunkmanJimbo
          Sharp lc-55p6000u won't turn on. The standby light is on but nothing happens when the power button on the tv or remote is pushed. I'm thinking this is a main board issue but they are expensive. I was wondering if anybody could tell me how to repair the main board I have. There is a repair service on Ebay but they're also expensive. Since there's a repair service for this main board I was hoping somebody could help me with the repair. The main board part number is 221999. Thanks!!...
          09-28-2024, 12:56 PM
        • pajdek
          Lenovo Y700-17ISK turn on and off
          by pajdek
          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
          09-20-2023, 02:49 AM
        • Egidio85
          SHARP LC-40LE814E does not turn on 2 flashes
          by Egidio85
          hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
          the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
          reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
          now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
          to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
          07-21-2023, 11:49 AM
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
