Polaroid TLA-04011c Red Light on, no power on
  • ryn0909
    Professor X
    • 122
    Re: Polaroid TLA-04011c Red Light on, no power on
    no sorry, i got rid of that tv years ago. i was actually trying to fix it for a friend, but to no avail.
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • lapfix
      HP OMEN NO power no light
      by lapfix
      HP OMEN : DAG35DMBAD0
      NO power ,no short ,no corrusion
      Consumption : when charger plg in = 0.004 amp
      Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
      when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
      No light at power button led
      All coils resistances :
      Pl 2001 =3v measured with kohm.
      pl 2004 = 5v measured with kohm
      pl 6001 = 49.7ohm
      pl 4012 = vccsa = 24.4 ohm
      pl 3001 =...
      11-03-2025, 07:48 AM
    • ipatch
      troubleshooting microsoft surface pro 4 no power no led charge light
      by ipatch
      hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
      10-05-2023, 11:59 AM
    • russpall
      LG 39ln540v - red light flashes twice, no power to LED driver?
      by russpall
      Hi there,
      I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
      The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
      08-27-2024, 01:07 PM
      03-31-2024, 02:12 PM
