Toshiaba 50HP66 Plasma SUS Board Question
  • TECHMECH
    • 21
    Hello, I have a Toshiaba 50HP66 which uses the common 50" 50x3 panel. I acquired this tv with the intention of repairing it. It originally had a flashing/scrambled picture. I replaced the ysus board (as it was making noise and cold). After replacing the ysus board and checking the buffer boards for shorts, I powered on, adjusted the pots to the correct voltage.
    The picture has improved, but now upon pressing the power button I get a white vertical line/lines that move across the display then a colored/blurred mis-discharge type image, finally the tv powers itself off. I suspect the zsus board as a failure because I hear a clicking noise coming from the zsus after the power off. The vsus drops from 250v (measured at the zsus board) to 60v. When I disconnect the cable going from ysus to vsus the tv will stay on. Again, I suspect the ZSUS board failed at the same time as the YSUS, but this does not explain the white vertical lines that move across the display.
    I hope someone knows the answer to this and can tell me if it is indeed the zsus or possibly the xsus at fault.
    Power supply measures properly at 196v, what seems to be happening is an overvoltage on the zsus tripping something and dropping the voltage, forcing the tv to shut down.
    Thanks in advance guys!
  • cadiman
    • Mar 2010
    • 397
    Re: Toshiaba 50HP66 Plasma SUS Board Question
    Unplug z board and see if power supply stays on. (You won`t have a picture)
    All pdp voltages are on the back of the pdp, upper right or left hand corner for va and vs, etc.
    There should be plenty of old posts for this L/G panel that will get you to the training manual.
    Good Luck!
    • TECHMECH
      • 21
      Update:
      I have replaced the ER IPM and the TV now will stay on without shutting itself down. I still hear a clicking noise from the lower part of the Zsus Board. Voltages are now stable attached are pictures in the order they display onscreen.
      I hope I attached the pictures properly using the manage attachments.
      • rayrod81
        • Oct 2010
        • 205
        If I remember correctly then your Vs is way too high. I think on these panels the Vs should be about 206V or close to that. A Vs that is that far out of spec will cause the set to shut down.
        • rayrod81
          • Oct 2010
          • 205
          Also you may still have a bad component on the Zsustain. Sometimes when the IPMs go bad there is a diode or mosfet that also goes with it. I can't remember at the moment the position on the board but if I can find it I will let you know.
          • TECHMECH
            • 21
            Hello, the Vs problem was fixed. It is stable at 196 where it should be, I have gotten the set to stay on now but the problem is the clicking noise and the bad picture as describe in post #3.
            • mbates14
              • May 2005
              • 169
              Replace the Y-buffers. Make sure your voltages are correct before doing so.
              ran into a 50HP66 that done just this. bad buffers. no Y-addressing.
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • PlasMatt
                LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                by PlasMatt
                I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                09-20-2025, 06:50 PM
              • Cooperr
                Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                by Cooperr
                I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                10-21-2025, 01:11 PM
