Sony Bravia no Picture
  • BenB
    • Feb 2014
    Re: Sony Bravia no Picture
    Originally posted by budm
    "IE 3A": It may be is LF for Little Fuse. I use PICOII fuse 3A rating from DIGIKEY.
    Thanks for the reply! I'm a complete novice when it comes to fuses. I searched for PICOII and there are so many. Does it make a difference which one I choose (see link below on the search)? Those are the 3 amp fuses. Is one better than the other?
    Also does anybody have any comments on where to get the the 5A 24V micro fuse (breadcrumb) that is on the BU board. Would digikey have that under some other search parameters? Or can I just use another PICOII fuse?
    http://www.digikey.com/product-searc...=0&pageSize=25
    Thank you!!!!
      I get bulk, the yellow one is the slo-blo, the green on is fast-blo which is what I use.
      • oldguy70
        • Sep 2014
        I have a problem with the F100 on tcon board, blown. My F1422 is ok as I have 12V to one side of the tcon fuse.
        Also had bent pin on tcon connector causing two pins to short together, probably due to not pulling the connector straight when removing.
        Anyone ever had fuse on tcon blow?
        • oldguy70
          • Sep 2014
          I would love to find a tcon schematic, but doubt I will find one.
          Anyone know where I can get one? I have the manual with other boards.
            "Anyone ever had fuse on tcon blow?" yes.
            • chlanman
              • Oct 2014
              • 15
              • canada
              #46
              Hello, gents im having the same problem with my KDL-55EX713
              Screen started going bad with lines on the left hand side only.
              Then gradually went to the full screen. Then went washed out, and then completely black now.
              This was over about 2 hour period.
              Now if i turn it on, just a black screen.
              Could this be the t-con ? I visually looked at the power supply board and all the cap's look to be good. When i turn power on there is a click
              Any suggestions?
              Where can i find schematics for my model?
              Thanks guys!!
              • tibimakai
                • Jan 2012
                • 3680
                Please do not post all over the place.
                heck for fuse on T-con board, near the connector coming from the mainboard.
                • djpat1974
                  • Nov 2014
                  • 65
                  • united states
                  #48
                  Re: Sony Bravia KDL32XBR4 i get two click
                  Bravia KDL32XBR4 i get two click sound i nee help with this can i jump to see if inverter is bad or main board
                  • djpat1974
                    • Nov 2014
                    • 65
                    • united states
                    #49
                    do anyone have a schematic for a sony Bravia KDL32XBR4
                      @djpat1974, you should start a new thread since your TV is not the same model as in this thread.
                      And also:
                      https://www.badcaps.net/forum/showthread.php?t=39740
                      • Jackching
                        • May 2017
                        • 127
                        Originally posted by mbates14
                        I work on these stupid sonys all the time.
                        there is a VERY EXTREMELY SUPER MINI TINY fuse on the signal board that popped when the t-con went bad. I am thinking smaller than SMD0603
                        you must replace this fuse. This fuse supplies the 12V to the T-con board, and if popped, you will get no 12V to the panel.
                        These boards are riddled with tiny fuses. id say theres maybe 5 to 10 of them in various circuits. there is one popped, and i think its near the center of the board on the back side.
                        I have this tv with the same symptoms. When you say the signal board are you referring to main board with the inputs on it?
                        • iglitare
                          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                          by iglitare
                          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                          Backlight seems to work, Sound (Setup menu after reset) works.
                          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                          With my small knowledge i would think at least the cables are good.
                          Can this happen because of a bad tcon board?
                          Or is it always a bad/shorted...
                          09-04-2025, 07:13 AM
                        • CyberPhoenix
                          Issue with picture quality of Sony bravia TV
                          by CyberPhoenix
                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                          01-22-2024, 02:08 AM
                        • Spc.
                          Sony Bravia KD43XF7596BAEP - Android no picture
                          by Spc.
                          Greetings everyone.
                          I also have Sony Bravia, model:
                          Sony Bravia KD43XF7596BAEP - Android.
                          What happend is that image dissapeared while we were watching tv.
                          Diagnostics:
                          1. TV turns on, no errors
                          2. Backlight turs on, no errors
                          3. Power indicator turns on, white color, no errors
                          4. Menu works on android, you can hear sound while switching channels
                          5. Volume up and down works via TV remote and via buttons
                          6. Tunner works, HEVC / MPEG-4 decoder works
                          7. I get audio from channels
                          8. No picture is present,...
                          05-19-2022, 04:28 AM
                        • KYBOSH
                          Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                          by KYBOSH
                          Previous owner said TV just went blank one day.
                          They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                          Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                          The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                          There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                          I just downloaded the Sony KD-75X7800F Service Manual and...
                          11-19-2024, 10:12 AM
                        • lmcancu
                          Sony Bravia 65x900F BL On but not picture
                          by lmcancu
                          I was watching youtube yesterday, when I paused it to go to the washroom. When I came back, the right side of the screen was showing half of the youtube channel and the left was black. I powered off/on the unit with the remote and now I have no picture whatsoever except for the bluish backlight. I did the factory reset (power + vol down), and now I when I power on I get the startup music, backlight but no picture.
                          I took the back cover off, and reseated all cables but unfortunately same issue. I took some voltage measurements on the main 2 headers from the power supply board and...
                          10-30-2023, 07:01 PM
