bad power supply voltage and slow motion image?
  • pr0cess0r
    • Jan 2011
    • 110
    Hello i have a samsung lcd tv thta is like in slow motion and im wondering if it can be the voltage of the power supply that is too high on sime lines and too low on one that make this ?
    i suspect the power supply sonce all caps are capXon but none are visualy bad. I need to get a ESR reader soon!
    thx for looking!
  • digge
    • Apr 2006
    • 296
    Re: bad power supply voltage and slow motion image?
    From what ive seen in the past its not impossible that caps cause that kind of failure. Not sure about tvs but ive seen a few routers where the cpu have worked but been in slowmotion due to not stable enough power.
    Probably someone else on the board could say more for sure if its possible for tvs.
    • truep
      • Aug 2010
      • 373
      Does the "slow motion" leave a trail behind the moving object? Does it have a red or green tint? If so, you probably have a defective panel. I've had two with the above symptoms and it was the LCD itself.
      • pr0cess0r
        • Jan 2011
        • 110
        i hope its not the panel but i must say it hink its the panel i recaped the psu i will test and report!
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
          I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
          https://www.ebay.com/itm/116497313155?var=416785404161
          Here are some of the description from the eBay seller
          The main parameters:
          1. Product name: High-power non-isolated DC boost module power supply.
          2. Product model: 100A2000W.
          3. Input voltage: DC12V-60V.
          4. Input current: 100A (maximum)....
          05-18-2025, 09:45 AM
        • Jembang
          coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
          by Jembang
          good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
          11-01-2024, 09:55 AM
        • defame5
          Rx 570 not giving image. Voltage measurements included.
          by defame5
          Hey all, I've been trying to fix a rx570 XFX XXX edition 8gb. Keep in mind I've no knowledge so I've been doing this solely using tutorials. Any help is appreciated.
          8pin connector led is open when pc boots, but nothing else happens (no image).
          Fans don't spin. Before the gpu broke completely, the fans used to spin at max rpm at the start and there were some wonky things happening in general, so it was probably defective already.
          Everything below is based on this video: https://youtu.be/2Yz7HfzggYc?si=UM8VOndmqJX1gfgJ
          PCIe pins are all ok. They have similar...
          12-21-2024, 05:27 PM
          LM358 LM358S-13 Datasheet
          The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
          Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
          10-07-2024, 04:12 AM
