Rx 570 not giving image. Voltage measurements included.
  • defame5
    • Dec 2024
    • GREECE
    Hey all, I've been trying to fix a rx570 XFX XXX edition 8gb. Keep in mind I've no knowledge so I've been doing this solely using tutorials. Any help is appreciated.
    8pin connector led is open when pc boots, but nothing else happens (no image).
    Fans don't spin. Before the gpu broke completely, the fans used to spin at max rpm at the start and there were some wonky things happening in general, so it was probably defective already.
    Everything below is based on this video: https://youtu.be/2Yz7HfzggYc?si=UM8VOndmqJX1gfgJ
    PCIe pins are all ok. They have similar resistance and not one is faulty. PCIe capacitors are all ok also, they have similar resistances.
    12V pin is ok. 3.3V is also ok.
    I tested the 8pin connector socket for short circuits but didn't find anything wrong.
    No visible damage/burnt components.
    I booted it with the heatsink unscrewed to check voltages and here is what I gathered:
    Everything below is based on this video: https://youtu.be/5oD69tIrU7c?si=cQbnSDhlDMxwOkT9
    GPU core doesn't heat up at all. Stays cold.
    12V voltage is ok (C157, C151).Click image for larger version
    3.3V voltage is ok (next to C157, C151).Click image for larger version
    At the 5V regulator on the back on the 3 legs I read 2.5V, 3.3V, 12.V and opposite of them I read 3.3V. Didn't read the suppossed 5V.Click image for larger version
    At the 1.81V on the back I correctly read 1.81V. One thing I noted was everytime I touched the probe on it to read the voltage, the fans spun for a split second.Click image for larger version
    Display rail read 0.92VClick image for larger version
    VDDCI/memory controller read 0VClick image for larger version
    1R0 (memory) read 0V
    GPU read 0VClick image for larger version
    Thank you and I appreciate the community this forum has developed
  • LaPCon_IT
    • Sep 2022
    • 82
    • Malta
    Hi, I have the same issue. Did you solve it?
      HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
      This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
      09-12-2024, 02:20 PM
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
      HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
      This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
      09-06-2024, 10:56 AM
      HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
      This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
      HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
      This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
