Sharp LC-52SB55U Power Opc Blinking
  • MazdaSpeed6
    • Mar 2011
    • 23
    #41
    Re: Sharp LC-52SB55U Power Opc Blinking
    Still haven't found the cable does anyone know where I can get one?
    • rayrod81
      • Oct 2010
      • 205
      #42
      Your only chance is to find a similar model with a broken screen. You will most likely not find this as an accessory.
      • Shane711
        • 493
        Long time since anyone has posted here but I save these cables. I have some if anyone needs to purchase one. Just get in touch with me.
        I have a LC-52SB55U I am about to work on as well.
        In my opinion, if this cable shorted out then you have something that spilt on the screen and caused it to short. But even if you replace the cable the LCD panel is damaged beyond repair. Want to try I have the cable.
        • monkey66
          • Jul 2021
          the cable was faulty in my case, cleaned it with WD-40 and 90% alcohol very well did the trick, if your cable was badly damaged , it is better looking for it online.
          and
          MazdaSpeed6, thank you for your hard work, without it, my TV will be cardboard s weight ;D
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • ronaldo17
            Power button blinking, Laptop Hp pavilion gaming 15-ak DAX1PDMB8E0 rev E
            by ronaldo17
            When I press the power button, nothing happens. All I can see is the power button blinking and never stopping.
            Here’s everything I’ve tried:
            -Removed the battery
            -Changed the power adapter
            -Replaced the CMOS battery
            -Changed the RAM.
            But my laptop is still blinking. However, in the morning after I wake up, the laptop will turn on.
            Here is my spec:
            -i5 6300hq
            -Gtx 950m
            -Hp pavilion gaming 15-ak030tx Laptop DAX1PDMB8E0 Rev E
            Now, I'm trying to fix the motherboard using the schematic I found
            If anyone can help...
            08-25-2025, 09:02 PM
