Re: Vizio VO42L FHDTV10A will not turn on...
Assuming this is equivalent to the NCP1207, the SMPS controller is bad.
The key is pin 6. The way this circuit works is it uses the rectified line voltage at pin 8 to charge the Vcc cap connected to pin 6. When the voltage at pin 6 reaches 12 V, the controller begins driving the power FET. Since the voltage at pin 6 never reaches 12V, the controller never starts. The voltage at pin 8 is somewhat lower than I would expect for a good IC, also indicating a problem with the IC.
PlainBill
Originally posted by richr69
View Post
PlainBill
