reviving vizio power supply
  • rubicondsrv
    • Nov 2010
    • 39
    I got a vizio 32"lcd with a bad power supply for $20
    initialy unit failed to do anything when plugged in.
    found a resistor blown, and replaced it, now yellow light on front flashes, and 5 volt lines read 4.2 and 2.3 volts.
    also found a transistor with signs of arcing corisponding with arcing marks on the metal housing of the tv.
    put arced transistor on my multimeter, it read 0
    i assume that is bad
    transistor is a1273, capacitors are "elite" brand, should i replace those at the same time as the transistor or not?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: reviving vizio power supply
    I would order new caps and replace the transistor. I would replace the transistor first and retest (to verify or find root cause). If it works, I would still replace them with some high quality low ESR caps.
    --- begin sig file ---
    --- end sig file ---
    • rubicondsrv
      • Nov 2010
      • 39
      I looked up the elite caps, and am replacing the big ones with panasonic FM's
      however the small ones are listed as "low impedance high ripple" what is sutibale for that?
      also another cap is an elite EA cap wich isnt listed
      • retiredcaps
        • Apr 2010
        • 9271
        Sometimes the datasheets for caps are not available, so I just generally go with Panasonic FR, FM, and FC (in that order).
        • rubicondsrv
          • Nov 2010
          • 39
          I also need a equivalent transistor to A1273
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            For jap/kor transistors you need to add 2S in front of the product code. So it's 2SA1273... nothing special. PNP -30V -2A 1W 120MHz. If you can't find an equivalent on your own please state your location so that we can point you to a parts distributor in your area.
            A working TV? How boring!
            • retiredcaps
              • Apr 2010
              • 9271
              findchips.com or ebay.com
              There is one auction on ebay for $1 + $6 USD shipping.
              • rubicondsrv
                • Nov 2010
                • 39
                thanks, got the transistor from electronix
                any reason to order a new primary cap?
                • Krankshaft
                  • Jan 2007
                  • 2328
                  Not unless it gives you warm fuzzies line caps even crap ones rarely fail and can be left alone.
                  • rubicondsrv
                    • Nov 2010
                    • 39
                    replaced the blown transistor, now both +5v lines read 4.2v when hooked up to the main board/led.
                    when tested without load they read 5v, but clearly dont have the power to drive the board.
                    still waiting on caps from digikey, will recap, then try again.
                    • mbates14
                      • May 2005
                      • 169
                      that component doesnt appear to be a resistor. it appears to be a FUSE.
                      • rubicondsrv
                        • Nov 2010
                        • 39
                        the red bloby thing?
                        that is a .1ohm resistor that replaced a blue .1ohm resistor with a hole in the side.
                        • mbates14
                          • May 2005
                          • 169
                          ah, ok, so its a fusible resistor.
                          • rubicondsrv
                            • Nov 2010
                            • 39
                            mabey, I just got it from a local shop, not sure what its specs are apart from being .1ohm and rated for 3 watts.
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                              by sam_sam_sam
                              07-01-2024, 06:34 AM
                            • shamsudeen
                              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                              by shamsudeen
                              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                              i know that in linear power supply the noise will be very low comparing to SMPS supply....
                              07-19-2025, 07:14 AM
                            • CMCM
                              Russound CA4 Power Supply Repair
                              by CMCM
                              Hello Everybody,
                              Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                              Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                              The outputs marked 12v and 20v are all measuring only 1v.
                              The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                              The capacitors physically look clean (no bludgesor leaks) and...
                              07-03-2025, 01:12 PM
