Phillips 50" Plasma - 50PF7321D/37
  • WinRyder
    • Feb 2011
    • 21
    Re: Phillips 50" Plasma - 50PF7321D/37
    Hi every, sorry for not posting anything the past few weeks, was in the hospital with something that has been going around here in south texas, sadly now i'm still having to test the voltage and keep my job lol... anyways I hope to have the voltage on the ssb to you'll in the next few days, also if you've seen me logged in, its because my wife uses this pc as well sometimes and I use firefox and I asked her to save all of the windows on the browser after she is done.
    Jason
    • f67bird
      Technician
      • Apr 2007
      • 57
      This is a known problem, and repairing the SSB requires replacing three ICs; total cost under $10, the parts are available from Digikey. Check the parts list in the service manual, do not order the parts listed in the schematic. The parts list lists upgraded parts.
      PlainBill
      Can you elaborate further on this?
      Part numbers, locations, photos?
      Thank you in advance.
      Learner
      • PlainBill
        • Feb 2009
        • 7034
        I'll have to get back to you on this. I'm trying to identify the service manual I used to solve the problem.
        PlainBill
        • PlainBill
          • Feb 2009
          • 7034
          This thread has the details, the parts are listed in post 12. The full explanation is later.
          The TV in question used the BJ2-4U PA / BJ2-5U PA chassis. The service manual is available here.
          The diagnosis is discussed in section 5.8.6 beginning on page EN 37; see note 1 at the top of the second column on page EN 38.
          The circuit is in the upper left corner of the schematic on page 52.
          Layout of the board is on pages 95 and 98
          The parts are on top of page 164 of the parts list. Note that 7U01 and 7U03 do not match the schematic; the parts list specifies upgraded parts.
          All parts were available from DigiKey.
          PlainBill
          • f67bird
            Technician
            • Apr 2007
            • 57
            Thank you.
            Another fix to put in the old memory bank!
            Learner
            • WinRyder
              • Feb 2011
              • 21
              #26
              Hi Plainbill, finally got some time to test the ssb voltage with the tv turned on, i got 12.39v then when it starts to flash it goes to the 0.03 (like before, i'd figured that is because it shut down to protect the components) my question is the ssb this one or this one. I'm guess its the second one but not 100% sure
              • PlainBill
                • Feb 2009
                • 7034
                The SSB is the second one. The first sale is for a main logic board (which serves a similar function to the tcon board on LCD panels).
                PlainBill
                • WinRyder
                  • Feb 2011
                  • 21
                  #28
                  so since the psu is reading right on voltage then it has to be the ssb? also meaning i repaired the psu correctly? lol
                  • PlainBill
                    • Feb 2009
                    • 7034
                    I don't know, but probably. If all outputs of the power supply are correct, but you get a blink code indicating the 3.3 or 2.5 supply is bad, yeah, that's a SSB failure. I fixed the one I had for under $10 in parts, but unless you have some experience with SMT devices, the price on that eBay auction was mighty attractive.
                    PlainBill
                    • WinRyder
                      • Feb 2011
                      • 21
                      #30
                      I have experience with SMT repairs, but at the moment i don't have the space to do that kind of work, so i will order the ssb and see how that goes, if not i will repost the ssb
                      • WinRyder
                        • Feb 2011
                        • 21
                        #31
                        Well i'm completely lost here... got the replacement ssb in, put it in and still flashing 4 - 4 -4 this is driving me crazy
                        • nine3
                          • Jul 2011
                          • 4
                          #32
                          Hello.... I have a broken 50PF9731D Philips 50" plasma. I don't have a remote for this set. When I press the power button on the TV, I hear only one click and only the LED8002 on the board in the center lights up. The LED8001 does not light up. I did notice that the 2 3300 uF 10V capacitors on the center board were blown. I replaced them with new low esr capacitors. But I still hear only one click when i turn on power and there is no picture and no sound. It would be great if someone can help me out. Thanks!!
                          • PlainBill
                            • Feb 2009
                            • 7034
                            You will find a white label on the back of the plasma panel that lists several voltages. The connectors on the power supply outputs are labeled. Check to see if all the voltages are actually present.
                            Pictures REALLY help.
                            PlainBill
                            • nine3
                              • Jul 2011
                              • 4
                              #34
                              PlainBill
                              Hi PlainBill. Thanks for the suggestion. I am attaching the picture of the SMPS board where I have highlighted 2 areas - I have marked the 2 3300uF capacitors which I have changed and the LED light which does not light up. I have visually inspected the rest of the capacitors and they look fine. When I connect the power, only one relay clicks, the other relay does not click. I checked the voltages on the connectors going to the X and Y driving boards. They show up as 0. The LED light on the front of the TV stays solid green, but there is no picture or sound. I also checked the fault detection flow chart in the service manual. It just says that if the relay does not click and the LED does not light up then the SMPS is bad. I dont really have any electrical background. It would be great if you can help me fix this TV.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                There are several tests I want you to do. First, hook up a signal source to one of the AV inputs - DVD player, video game, anything which you will know is producing a video signal and sound. Next, turn on the power, press the volume up button several times to increase the volume, then press the input button to step through the various inputs. Do you hear sound at any point?
                                Next, I want an over-all picture of the back of the TV, and a second picture of only the power supply. That one I will need as close to 2000 x 2000 resolution as possible. I am particularly interested in the labels on the connectors, so it may be necessary to disconnect the output cables from the power supply, and even take several pictures.
                                PlainBill
                                • nine3
                                  • Jul 2011
                                  • 4
                                  #36
                                  PlainBill
                                  Hi PlainBill,
                                  I followed your instructions. There was no sound or video. I took a short video clip of the problem and also some pictures. I compressed them and uploaded onto megaupload. Here's the link to download the files. http://www.megaupload.com/?d=9LST69AB . These are high resolution pics so you should be able to zoom into them and still see clearly. Do you think there would be more faulty caps on the board which can cause this problem? Thanks!!
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Hi PlainBill,
                                    Error message: "The file is temporarily unavailable".
                                    PlainBill
                                    • nine3
                                      • Jul 2011
                                      • 4
                                      #38
                                      PlainBill
                                      The link seems to be working for me. I am not sure why you got the error. You may want to try again. After you click on the link, there would be a 45sec timer on the right side of the screen. Once the 45 secs are done, you should be able to click on "regular download". Let me know if it still does not work for you.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Well, that was pretty much a waste of time. More than 10 mintes to download, one popup that made it past my blocker, and the pictures didn't help.
                                        I've marked up the picture of the power supply and circled a number of connectors. And it looks like I missed one. The labels on these connectors are obscured in some cases.
                                        What I need is the voltage of each of those outputs. If Vs appears on several pins of one connector, or on more than 1 connector, measure it only once. Ther is no point in measuring the voltage on any pin labeled Gnd.
                                        PlainBill
                                        • WinRyder
                                          • Feb 2011
                                          • 21
                                          #40
                                          Hey Plainbill, i've tried, a new ssb, and a new power supply... still nothing where should i go from here? I've tried old psu with new ssb, new psu with old ssb, new/new. Also to add these parts i purchase were brand new not used or anything. I hope you have some advice for me cause this is getting expensive lol
                                          WinRyder
                                          • Uranium-235
                                            Phillips 50PF7321D/37 Plasma slow reboot
                                            by Uranium-235
                                            Customer said if he keeps it on for a long time, turns it off, and later back on, it takes 10 minutes to get to proper brightness. Is this just a cap issue? I didn't have time to take it apart I was just there to drop a repaired laptop off
                                            12-27-2021, 09:14 PM
                                          • ArMaaN376
                                            Samsung PS51E550 Plasma TV
                                            by ArMaaN376
                                            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                            Opened TV cover & observed foll
                                            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                            How to confirm Y -Buffer board...
                                            06-19-2024, 04:05 AM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • KYBOSH
                                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                            by KYBOSH
                                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                            No picture but you hear the TV static (white noise) playing loud and clear.
                                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                            But it seems they didn't get too far and just left it.
                                            When I first took a look I was amazed at how pristine the inside looked.
                                            Its as if the TV had been in a time capsule.
                                            Caps looked like they were just pulled off the self.
                                            Copper coils had no sign of corrosion on...
                                            02-01-2023, 11:10 PM
                                          • porfyriadhs
                                            Samsung Plasma PS51D6900DS Bootloop
                                            by porfyriadhs
                                            Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                                            Thanks a lot !!
                                            10-19-2023, 11:31 AM
