Sylvania/Funai DVL515SLD TV
  • mbates14
    • May 2005
    • 169
    This TV was part of a DVD package.
    Anyone know how to get into service mode? or have a copy of a good EEPROM image?
    It works fine, but the picture is exactly 180 inverted on the colors. like the old time CCD camera "negative" effect.
    My guess is corrupted EEP.
  • dbuergi
    MacBook Pro A1990 820-01041A strange / inverted colors and faded look on display
    by dbuergi
    i got a A1990 which shows strange colors. Sometimes looking faded or like a water mark and only visible when the cursor moves over the spot. With an external display everything looks fine.
    So is there anything i can do on my own to fix this issue?
    It doesn't look like the flexgate macs i have seen....
    09-03-2024, 06:39 AM
  • j879
    Samsung QLED QN75Q8FNBFXZA inverted/negative color
    by j879
    hi guys,
    My 5 years old SAMSUNG QLED got color inverted somehow. I have tried reset, replace mainboard as well as the driver board without luck. The issue must be on the circuit on panel skinny board or so. For this model I could not find the dedicate T-con board so AS15 replacement is not applicable..
    I have upload the pictures
    Maybe I should measure the gamma voltage but I couldn't find the right place.
    Any idea would be appreciated....
    07-12-2024, 12:23 PM
  • kotel studios
    Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
    by kotel studios
    Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
    State I got it in:
    Squealing from the PSU
    After logo I get a blank screen
    After 10 seconds of having a blank display w/ backlight the TV dies
    Give it 7-10ish seconds again and it starts to bootloop.
    What I did so far:
    Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
    Checked all voltage rails:
    5VSB - 4.8V
    AMP+13V - 14.4V
    13V - 12.98V (in manual 12V)...
    09-21-2025, 02:00 AM
  • budwich
    Lithium 12v tool battery charger... no negative connection?
    by budwich
    I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
    03-18-2025, 09:12 AM
  • silikon77
    Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
    by silikon77
    Hi!
    Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
    Found some advices watching youtube nad came up with this:
    It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
    I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
    See attached picture.
    I tried a few combinations to block individual clock...
    01-02-2025, 02:26 PM
