Hitachi 55hds69 No Picture
  • R_J
    • 9588
    Re: Hitachi 55hds69 No Picture
    It could be that the Main digital board became seperated from the Sub digital board. They use a 200 pin connector between the two boards, The sub digital board handles all the inputs except the hdmi and the tuner. The hdmi is mounted on the main digital so it might see the device but the video/audio won't be processed.
      • 12276
      • U.S.
      [QUOTE=diif;910283]You haven't seen a cracked plasma that works.
      WHAT??? YES I've seen MANY cracked plasma tvs that
      still worked. Try a little research before you make an ignorant statement.
      • KYBOSH
        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
        by KYBOSH
        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
        No picture but you hear the TV static (white noise) playing loud and clear.
        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
        But it seems they didn't get too far and just left it.
        When I first took a look I was amazed at how pristine the inside looked.
        Its as if the TV had been in a time capsule.
        Caps looked like they were just pulled off the self.
        Copper coils had no sign of corrosion on...
        02-01-2023, 11:10 PM
      • navagator
        Hitachi Power Supply Unit Interchangeability
        by navagator
        I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
        Does anyone know if these 2 power supply boards are interchangeable?
        Thanks.
        01-08-2024, 07:53 PM
      • Goldenmonkey
        Samsung pn59d530a3f no picture after power supply replacement
        by Goldenmonkey
        My samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
        after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
        Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
        04-07-2023, 09:39 AM
        by sam_sam_sam
        07-01-2024, 06:34 AM
