42" Philips-Won't turn on
  • JAWII
    • Dec 2010
    • 8
    Re: 42" Philips-Won't turn on
    So y'all think it's relatively the same problem?
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Yes.
      These are bad capacitors:
      http://www.google.com/imgres?imgurl=...w=1024&bih=667
      You can see how the tops of them are pointed, when they should be flat.
      Take off the back panel of your TV, and check the capacitors.
      If any of them have a rounded top, they are bad!
      Capacitors are can-like things that look like towers on the circuit boards.
      While the cover is off the TV, it would be a good idea to take some pictures of the circuit boards.
      -Ben
      Muh-soggy-knee
      • JAWII
        • Dec 2010
        • 8
        Originally posted by ben7
        Yes.
        -Ben
        Appreciate that Ben, yea I did TV repair for close to 15 yrs, but about as many years ago. Then they didn't have flat screens then, but I'm pretty sure the block diagram/flow chart is pretty much the same. Also caps don't have to have rounded tops to be bad or leaky and screw things up. Jumping them with a good cap will sometimes show them but you have to be careful what circuit your doing that in as it can make things worse. Best things is just replace caps in RC timing circuits which is where I'm pretty sure this will be. Primarily the electrolytics.
        Mine at present is back to working so I have to wait for the problem to arise again. I really would like to hear back from grizzly with some pics and really really if he gets it repaired.
        JW
        • PlainBill
          • Feb 2009
          • 7034
          JW
          Intermittent problems such as you describe are probably due to bad solder joints, not bad capacitors.
          PlainBill
          • johnstokley
            looking for a circuit diagram for power supply for a phillips model 42pfl5432d/37
            where can i get this diagram for power supply
            • Dgtech
              E. Technician
              • Apr 2009
              • 1462
              • Steeler
              #26
              Here are a couple of threads already started on this TV. You may find what you need here. If you have anything to add, add it in one of the threads of that model number.
              https://www.badcaps.net/forum/showthread.php?t=14491
              https://www.badcaps.net/forum/showthread.php?t=9736
              Read them and join the one that best fits.
              • jwsdevil
                • Aug 2011
                #27
                hello,i dobnt if you are still tryin g to fix your tv but if so, if the green light comes on when u press the power button . but u have no picture, the master inverter board, on the left hand side of the tv , has three small S.M.F. ON IT two of them are white and easy to see, check these two first. if they are good. there is a very small black smf on this board all so. i have seen this set blow this fuse on many sets and cause your problem. let us know what u find. joe
                • skelator2112
                  • Dec 2011
                  #28
                  Sorry if I am jumping in on the wrong thread here but,, I replaced the 3 caps on my 42PFL5432D power supply board,, and still I am getting this squeaking about every 1 sec, and of course no picture. Any thoughts. Its very difficult to locate the squeak but I think it is from the center transformer,,just not sure.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Multiple posts of the same problem in different threads is a good way to get ignored. Failing to give meaningful information increases the odds.
                    1. Where are the pictures of YOUR power supply?
                    2. Which caps did you replace?
                    3. What brand and series of caps did you use?
                    4. What were the original symptoms?
                    5. What are the output voltages of the supply?
                    PlainBill
                    • Malayac
                      • Jul 2015
                      • Ireland
                      #30
                      My phillips T.V. won't turn on. The light turns on for a second, but then....., the red led light flashes 3 times but nothing........ and so on. Help please.
                      Model number - 42PFL56O4H/12
                      • pajdek
                        Lenovo Y700-17ISK turn on and off
                        by pajdek
                        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                        09-20-2023, 02:49 AM
                      • RdeveLabs
                        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                        by RdeveLabs
                        To all the members here...
                        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                        05-05-2025, 04:59 AM
                      • robante15
                        Acer Aspire 4520 won't turn on after reboot
                        by robante15
                        Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                        It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                        The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                        If I remove the...
                        04-06-2024, 06:50 PM
                      • masoksian
                        Dell latitude e7470 not turn on .power buton on off and Run Power problem
                        by masoksian
                        I am dealing with the problem of turning on and off my Dell e7470 notebook.
                        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                        The system does not turn on, there is no post.
                        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                        The problem continues in the same way.
                        I tried to turn on the Fn key, nothing came to the screen....
                        02-15-2025, 12:08 PM
                      • dqtech
                        lenovo x240 nm-a091 wont turn on
                        by dqtech
                        i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                        board number VIUX1 NM-A091 REV:1.0...
                        02-07-2024, 01:57 AM
