Philips 23PFL5522D/05, black screen red power flashes
  • quartz
    • Nov 2010
    • 14
    Hello, have already had a suggestion of the control circuit board, after reading about the power problems on a monitor, like to check in case anyone has different know-how pls
    The picture went slightly garbled and flakey, sound was fine, displayed this "stable" for 5 minutes. the next day, was good again The day after, went black
    connecting to power after 10 mins disconnection, the red power flashes about 6 times, then does about 4 flash-flashes, then the speaker starts blipping, and the red flashes fast constantly, with the speaker blipping every few seconds
    ther's no obvious component failures or burn out, altho a couple of the caps on the power have very slight bloating
    there is a fizz/quiet/fizz/quiet
    many thx
  • Toasty
    • Jul 2007
    • 4171
    Re: Philips 23PFL5522D/05, black screen red power flashes
    Photos of both boards and swollen caps please.
    Part number of power board? Do not keep the unit plugged in. The fizz-quiet routine can be a mains cap gone bad. If it fails -badly- while plugged in or trying to turn on, a $10 repair could be $100.
    I can't locate a service manual, but PlainBill may have a source once he wanders through here.
    Toast
    veritas odium parit
    • quartz
      • Nov 2010
      • 14
      stock photos attached, but circled the caps which have slight bloat (very, very slight, just to the touch)
      but have no other visible faults on either of them, or signs of burnout, or any smells
      power: DAC-12M058
      ctrl board: 3139 123 62613 WK713.5 (this replacement is what ive been advised, at about £40)
      i believe there is another board hidden under some metalwork on the left.
      i think i attached inline wrongly
      • Toasty
        • Jul 2007
        • 4171
        If your caps are the same as the -bloated- ones in the pic , then a complete recap is called for of the power board -first-. If your mains cap is also Rubycon, then that can be left alone.
        The fizzing is the power supply trying to start and failing because of the bad caps.
        Again, picture attachment is good!
        By the pic, it seems you have 13-15 caps to replace.
        Google cache shows something from ebay.co.uk for the power board ~£50 incl. shipping. Nothing presently though. If you were to buy the board, you'd most likely be back in the same boat in a short while.
        If the Power board is bad, there is no way to conclude the Logic board is a problem, unless you can swap it to another set.
        Toast
        veritas odium parit
        • quartz
          • Nov 2010
          • 14
          thanks when you say bloated, there's the 3 caps which have a slight bulge to them, does even the slight bulge indicate the insides are bad, do 3 caps like that recommend replacing the whole set (all the rest are flat - not a problem if it is, just to check)
          • Toasty
            • Jul 2007
            • 4171
            A slight bulge is like being a little pregnant.
            The rest need replacement or you'll be chasing problems for a long time.
            Toast
            veritas odium parit
            • PlainBill
              • Feb 2009
              • 7034
              Toast
              PlainBill
              • quartz
                • Nov 2010
                • 14
                bit of a bump but...Thanks guys. absolutely brilliant. learned info.
                did the replace not being entirely sure if I was expecting, and great.
                • JunkmanJimbo
                  Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                  by JunkmanJimbo
                  Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                  No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                  Please help. Thanks in advance!
                  08-12-2025, 11:45 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
