LCD backlight goes off after 10 sec to 10 min
  • jeepster
    • Nov 2010
    • 3
    I have a Conia brand LCD TV - I think it a rebadge name by some importer.
    Anyway, the backlight drops out after a while. If you switch it off and on
    again, it lasts about 10 seconds before off. If I wait till next morning, when it
    is cooler, then maybe goes 20-30 seconds. But the strange thing is if I leave it
    for a few weeks, then try again, it lasts 10 minutes before the backlight
    goes out. Does this sound like a bad electrolytic in the backlight power
    supply? I have search in LCD monitor forums, and it seems usually the
    backlight goes off after 2 second or less.
    The reason I ask is that the case of this TV is a prick of a thing. It has 2
    halves clipped together in such a way that two people would be required
    to lever it apart with small screwdrivers. I am hoping it is a simple fault to
    justify the hassle of getting at bad components.
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: LCD backlight goes off after 10 sec to 10 min
    You're gonna have to get into this thing, theres no way around it. I've noticed some cheaper, non-brandname sets have unusual cases and weird ways to properly open them. Once you do, post pics of the boards inside using "Manage Attatchments" on the post page.
    • PlainBill
      • Feb 2009
      • 7034
      This sounds similar to a problem I had with a Philips LCD, although the 'On' time was often much shorter. That was due to a bad transformer in the inverter.
      PlainBill
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • DanPoka
        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
        by DanPoka
        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
        02-15-2025, 05:05 AM
      • Comp_Pro
        No Backlight Macbook A1990 820-01041
        by Comp_Pro
        Hello all,
        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
        Tests performed:
        There is no backlight even with a good screen.
        Backlight IC is receiving the correct support voltages.
        Fuse F8400 ok
        Current sense resistor R8400 ok
        Backlight IC is receiving 3.3V on enable pin.
        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
        Backlight IC receiving 5V from PP5V_G3S
        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
        05-06-2024, 10:23 PM
      • cheebster
        iPad Pro 12.9 5th Gen Backlight Issue
        by cheebster
        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
        Anyone...
        05-20-2025, 09:17 AM
      • canadaboy25
        LG Flatron 24EN33TA No Backlight When Cold
        by canadaboy25
        I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
        I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
        03-07-2023, 12:23 AM
