75r648 TCL 8K Mini LED White Horizontal Lines
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    TV turns on, lights work sound works.
    TV shows white/gray horizontal lines across the whole screen as shown in picture. TCON is getting 12v at fuses, VCC 12v.
    First experience with 8k and mini LED. Does this picture tell you anything?
    Apparently a "certified TCL tech" looked at this TV before I got it free and said it's a Tcon issue but said he couldn't be sure and wrote it off as a loss and they replaced for him.
    Any tip or trick on where to start would be appreciated.
    Going to research the lines. Also going to disconnect each ribbon here shortly and give results for this, just documenting and seeing if anyone in the few hours before next post is familiar with this
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Re: 75r648 TCL 8K Mini LED White Horizontal Lines
    Lol simple enough, I disc far right cable and get 3/4 picture. So looks like we are in panel land potentially
    • EazyBone
      • Jun 2023
      • 1362
      • United states
      I will say looks pretty good. Tape method worked and this TV does look great. I don't actually notice any differences EXCEPT for when I do screen test I can see small color issues.
      Now I don't think I can sell this, anyone know how long tape method works for?
      • Storyteller12
        • Jun 2020
        • 625
        I seen the tape work for years with no problems.
        • Diah
          • Feb 2013
          • 6558
          yours Photo its T-CON Issue
          • EazyBone
            • Jun 2023
            • 1362
            • United states
            You think the tcon is causing this? With the tape there, the TV has a green line vertical on far right and a small white line across top of TV that doesn't go away.
            I'd be interested in messing around.
            TV turns on 3/4 picture with the far right ribbon disconnected from the tcon and I tried buffer boards and both work. Any other ribbon disconnected won't show problem
            Anything I could check in order to fix this? Or you are certain a Tcon would fix it
            Using the tape and moving it around I would get different colors and patterns of horizontal lines looking exactly the same. Only when I put in the spot it's in would I get a picture and something useful
            • Diah
              • Feb 2013
              • 6558
              you need to take out the bezel, and check if there are no COF ribbon on the panel side left & right.
              NO COF = 100% T-CON
              COF there = Panel issue .... one of the side COF get hot. and can be removed carefully from the Panel glass
              • EazyBone
                • Jun 2023
                • 1362
                • United states
                NO COF = 100% T-CON
                Is there an easier way then taking bezel off? Lol this TV is 90lbs.
                Looks like screen is glued down, here's a pic, I would assume it wouldn't have them then?
                • Diah
                  • Feb 2013
                  • 6558
                  how much the thickness of the bezel in mm ?
                  • EazyBone
                    • Jun 2023
                    • 1362
                    • United states
                    The space between screen/bezel is 1 mm and the bezel piece is 2.73mm
                    • Diah
                      • Feb 2013
                      • 6558
                      its hard to tell... but 8K from 2021 most likely they have side COF same story when first 4K come out.
                      but what are this line on yours photo? aren't the same area where the lines showing on the screen ??? ?? photo flipped.. the line showing in yours photo on the top
                      • EazyBone
                        • Jun 2023
                        • 1362
                        • United states
                        That is top of TV, and space between bezel. The line is just a little dust
                        • Diah
                          • Feb 2013
                          • 6558
                          dust line at the same area where are the line showing.. are big story .. why only this dust in line !!!! you need to be detective before technician
                          • EazyBone
                            • Jun 2023
                            • 1362
                            • United states
                            I don't think this is the same thing we are talking about here. This little bit of dust isn't the problem here lol. The entire screen is full of lines, with tape I have a small line there and a vertical one. You asked what the line was and I think you are just seeing a reflection or something. Just a space between bezel
                            Also @storyteller thx for response on tape fix
                            • Diah
                              • Feb 2013
                              • 6558
                              one of my principle, who call tape mask as repair method, he / she just playing clown to them self. ( whom sell or thing he did repair with tspe then he is clown) .. at the end i will never join any threat regards those clown.
                              • EazyBone
                                • Jun 2023
                                • 1362
                                • United states
                                Well good thing I don't sell anything with tape lol, that's unethical to me. I actually give tape tvs away free to people and I explain to them as best I can what happened to tv.Or I just part the TV out and put boards on eBay and dump it. So if you are assuming I do that well it's wrong. That being said, a neighbor wanted the TV and I was asking how long because I don't want to give it to them and have it break immediately and have it waste both our time. And she didn't care, she is happy with it. But I'm entertaining now the idea that tcon may be causing this and just trying to learn some more and potentially fix the tcon so I can give her a fully functional tv instead.
                                So diah no it's not a "fix" lol but that's what the YouTube videos call it. The tape fix
                                  • 12328
                                  • U.S.
                                  Tape method is just a way to get more use out of the junk tv's that they put out nothing more, replacing panel is not economical. Reselling not ethical. So if someone can get more use out of the junk tvs that these companies are making, before they have to buy another new tv, then sure tape it.
                                  • EazyBone
                                    • Jun 2023
                                    • 1362
                                    • United states
                                    That's exactly what I'm saying. If it's inner parts aren't worth anything on eBay, I tape it and donate it to someone with that understanding. If it's parts are worth something I just part it out to eBay. This one would be parted out, but neighbor wants it. I'm first going to get a Tcon though. Not that expensive, and worst case I'll just resell the new one since there is no stock on eBay. Diah seems pretty certain it could be tcon, and well we are about to find out. I'll post results if it works or not.
                                    • EazyBone
                                      • Jun 2023
                                      • 1362
                                      • United states
                                      Was not tcon
                                      • Diah
                                        • Feb 2013
                                        • 6558
                                        Was not tcon
                                        my post #7 .. this why we as i suggest to take out the bezel to check if there side cof... at same time inspect the panel glass rand at the line area... but you aware of the set weight .. i am free from any guilt lol
                                        • thstuff
                                          SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
                                          by thstuff
                                          This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
                                          Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
                                          1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
                                          2) Waited 30 seconds, then pressed remote Power button and "Select language"...
                                          01-30-2023, 05:01 PM
                                        • krsta
                                          P1 Mini pocket projector horizontal lines
                                          by krsta
                                          I found P1 Mini Pocket Projector in original box without remote on the street.
                                          Charged the battery and when powered on noticed 1, 2 or 3 distorted horizontal lines.
                                          I havent opened it yet, the warranty sticker in unbroken.
                                          I was wondering if anyone knows what the source of the problem could be, maybe a known issue. Take a look at the attachments.
                                          Thanks....
                                          01-23-2023, 08:47 AM
                                        • ggil44
                                          Sony XBR-65X750D Horizontal lines bottom of screen
                                          by ggil44
                                          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                          05-30-2023, 07:51 PM
                                        • noisykid
                                          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                          by noisykid
                                          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                          12-30-2024, 07:15 PM
                                        • reaper422
                                          DELL P2717H 27 inch white horizontal lines on screen
                                          by reaper422
                                          I have a problem with the Dell monitor whit LCD Panel MV270FHM-N20
                                          that starts with a normal picture but after three or four seconds of work, it starts to draw horizontal lines progressing from the bottom to the top.
                                          The power supply generates stable voltages.
                                          The power supply of the matrix is 5 volts, which is also stable.
                                          I don't think normal sounds can be heard from the LVDS board.
                                          After measurements are made on the test points on LVDS, the measurements are
                                          VGH 23.7v
                                          AVDDS 11.7v
                                          AVDD 11.7v
                                          VOFF -7.7v
                                          VGL...
                                          02-19-2022, 05:41 AM
