Samsung GU50TU8079U bad panel diagnosis
  • Ierwin
    • Jul 2017
    • 103
    I was given this Samsung GU50TU8079U that would power cycle after a couple seconds, sometimes a few minutes. The screen would turned cloudy dark with the backlight still lit and then the sytem would restart.
    Its one of the newer screwless Samsung models that I read a lot about panel failures here. It does not have a sperate T-CON board, just one ribon from the mainboard to the panel board and a U-shaped ribbon cable connecting the other half.
    I went through the usual diagnostics:
    unplugged the mainboard -> tv stayed on
    removed the U-Shape robbon -> tv stayed on
    I then started to tape off pins of the ribbon between the halves.
    It was a lengthy procedure to play with the tape because the set would sometimes work perfectly fine for 10 minutes before it restarted.
    The least tape that I can get the tv to start with results in heavy horizontal lines though, not usable at all.
    So I removed all the tape, put everything back together and was about to put the tv in a corner, when it suddenly came on and stayed on.
    There was nothing but a single distorted line on the right side of the screen, only noticeable on solid color images.
    The tv worked like this for a couple of days.
    Then suddenly it turned off and started to power cycle again. This time much faster, restarting right after the program starts to play.
    I was wondering if there is anything I can still try before I call it a brick.
    Ive read that some people found shorted diodes or caps on the panel boards, but I'm not exactly sure where to look and could not find anything yet.
    I would be able to borrow a themal camera too, if that could help diagnose the problem.
    Any Ideas are welcome.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4535
    • Italy - Milan
    Re: Samsung GU50TU8079U bad panel diagnosis
    in panel stripe boards: test every resistor, if good remove T16, T15 and re test
    • Ierwin
      • Jul 2017
      • 103
      Are t16 and t15 protection diodes? And is there any way to test them before e pull them off, because I won't be able to put them back
      • lotas
        • Jan 2016
        • 4840
        • Russia
        Check these test points with a multimeter for low resistance or a short to ground (GND).
        • Ierwin
          • Jul 2017
          • 103
          Ich checked all the points with 2000Ohm Setting on the Meter.
          All were higher except for 2 on the right side.
          VGK @530Ohm but only one direction
          VSS @1000Ohm
          • Ierwin
            • Jul 2017
            • 103
            I went and carefully checked T16 and T15 again.
            There seem to be several shorts across the pins left to right.
            Before I rip them off as suggested I would like to undertsand what they usually do though. Could you explan what they are?
            • Diah
              • Feb 2013
              • 6550
              first clean panel edge boards from the moister you have because of cleaning or water liquid
              • Ierwin
                • Jul 2017
                • 103
                I did not use any water to clean but of course there might be moisture... I could evaporate using a heat gun and just carfully warm it up a little bit?
                I also was able to read the marking on T15 and T16: 5R2P so obviously those are esd protection diodes... not saying I know what they are there for
                • lotas
                  • Jan 2016
                  • 4840
                  • Russia
                  "removed the U-Shape robbon -> tv stayed on"
                  Try this.
                  • Diah
                    • Feb 2013
                    • 6550
                    no... never use any heat ... just with cotton cloth and alcohol massage the COF ribbon and the complete boards..
                    after you do and its clean... just plug out one side the U ribbon " ribbon cable like letter U " you have on each side one a time and plug in see what result you have
                    • Ierwin
                      • Jul 2017
                      • 103
                      Try this.
                      with the ribbon removed completely the backlight stays on but no picture of course. The tv is currently set to some samsung streaming program via Wifi. The sound is not constantly on but without a picture its hard to tell if there is connection problem with the source or if the tv is not actually fullyfunctional.
                      I taped the 14 pins and the tv reboots again.
                      Which is strange because a couple days ago I managed to have it stay on with fewer pins taped but had black lines then.
                      Will clean with isopropano now
                      • Diah
                        • Feb 2013
                        • 6550
                        dont do any tape.... just do one time for each side u ribbon disconnected.#
                        did the set stay on and on which side u ribbon disconnected ....
                        • Ierwin
                          • Jul 2017
                          • 103
                          If I disconnect the C-shaped ribbon on any side the backlight stays on.
                          The sound stops after about a minute but it does not make a difference what side of the ribbon is connected.
                          with both sides of the ribbin connected the tv reboots right away, most of the time before any sound comes on, or a second after
                          • lotas
                            • Jan 2016
                            • 4840
                            • Russia
                            On these 14 pins you need to experiment to see what will be best according to the image.
                            • Diah
                              • Feb 2013
                              • 6550
                              he never have image at any case... but the sound cut down... we have issue on main boards
                              its sound to me panel esd got defect short then mb suffer at dc dc converter... so it is much u have open r / l some whereon MB
                              • Diah
                                • Feb 2013
                                • 6550
                                hey did you put the set laying on the yours bed so u just notice the sound and back light ... not the screen self ....lol
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4535
                                  • Italy - Milan
                                  the 2 center pins are tied together and to gnd, the other pins must not at gnd..
                                  • Diah
                                    • Feb 2013
                                    • 6550
                                    when the demos come , angels flee..
                                    goof luck with yours esd removes LOL
                                    • Ierwin
                                      • Jul 2017
                                      • 103
                                      right now it is sitting face down on my desk on blanket, yes. But of course I lifted it up to check the screen :P
                                      I dont know what has caused this but the behavior now is different from what it started with.
                                      1. When I got the set it rebooted after 2-10 minutes
                                      2. after playing with tape and giving up it stayed on for hours with good picture except for 2-3 tiny lines
                                      3. after a couple days it suddenly turned off and restarted immediately
                                      4. playing with tape again I was able to keep it turned on but there were lines all over the panel (had to tape ~5 pins)
                                      5. now taping all 14 pins is not enough to keep it from rebooting and the sound cuts off after a minute.
                                      I am one step from cominng to the obvious conclusion that this tv is haunted
                                      • Ierwin
                                        • Jul 2017
                                        • 103
                                        that is exactly what I measure about the GND connection. Only the center pins. No short to GND fro any other pin.
                                        • learnmore
                                          Samsung UE70TU7020K Which lines to tape on a bad panel
                                          by learnmore
                                          Hello Community,
                                          I'm working on a Samsung UE70TU7020K.
                                          It looks like a bad panel. There is only 1 FPC cable from the Tcon (built into mainboard) to the panel.
                                          I'm using a piece of tap a few mils (covers about 8-10 pins), at different locations and have had varying results but nothing that is remotely watchable (multiple lines across all the screen, half screen and total black out on screen). The buffer board is divided into 3 boards. I've disconnected the end board one at a time but each time the screen was totally black. I presume it's because the potential...
                                          03-15-2024, 03:01 PM
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • NWArkGuy
                                          Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                          by NWArkGuy
                                          Well, I will be the first to admit that I screwed up...
                                          In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                          I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                          I have 2 that I have found and have in my possession. ...
                                          10-12-2023, 10:13 PM
                                        • KYBOSH
                                          Samsung UN50TU8000 - Dead Panel Forensic Questions
                                          by KYBOSH
                                          I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                                          When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                                          When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                                          Later I checked for shorts on the panel PCB boards but could not find anything.
                                          When I took a look with the FLIR i noticed the 2 resistors...
                                          08-10-2024, 08:39 AM
