xr-55x90j power issue
  • EazyBone
    • Jun 2023
    • 1347
    • United states
    xr-55x90j was picked up free and there is no standby light at all.
    I have checked the PSU and it feeds 12v to main board and correct voltage to the LED driver.
    I have forced the backlights on and they work through the PSU.
    The main board is supplying .178 to the tcon fuse which shows it as 8a/35v.
    I try to hit power and the numbers don't change nor does any light.
    Is this safe to assume the main board failed here? Anything I should check.
    Also there is a main board for this and 65inch which seems to be cross compatible.. would I need to program it before sticking it in or something? That is, if it's main board issue
  • EazyBone
    • Jun 2023
    • 1347
    • United states
    Re: xr-55x90j power issue
    When jumping tcon on the tcon 12vtcon line goes up to 1.4v. the cap shown in pic is only hitting 1.4v also. I would assume that this is not correct. Any direction for me on this?
    Main board gets 12v but there is no indicator light either and power button does nothing. Any direction? I'm but lost here
    • Diah
      • Feb 2013
      • 6397
      unplug the socket on t-con which feed the 12v. then do it a you did before .. main boards disconnected and run psu as stand alone with out MB and t-con see if the 12v of tcon correct or not
      • EazyBone
        • Jun 2023
        • 1347
        • United states
        Sorry forgot to put pic, yes will try diah.
        TCON AND PSU connected (no main board or BL) voltage 1.4v to tcon12v when jumping
        PSU standalone, no tcon connected. TCON 12v line is 2.06volts when jumping
        • Diah
          • Feb 2013
          • 6397
          so your t-con 12v on psu need to work on
          • Diah
            • Feb 2013
            • 6397
            BTW,,, you need STB connect to PW.on when you do t-con 12V_on
            • EazyBone
              • Jun 2023
              • 1347
              • United states
              Yes I have power on, stby on and tcon on jumpered.
              How does this explain no standby light though, odd. As other voltages okay.
              I'll do more digging i guess
              • Diah
                • Feb 2013
                • 6397
                don't bother with LED indicator... its Android.. and the indicator digital can be turn off from tv setting
                just follow the t-con12v on cold side
                • EazyBone
                  • Jun 2023
                  • 1347
                  • United states
                  This is what I get so far. Purple is where all the beeps go on the line. Then I lose it, I don't really know how to trace a line well, anyone know of a informative thing?
                  There's only one cap along the line that I see which is the one from post 4 first picture.
                  This is where I'm at
                  Edit, I just pulled that cap off to test and it's 325uf which is pretty spot on.
                  • Diah
                    • Feb 2013
                    • 6397
                    you have low currents on this line as you wrote 2.06V. its much like you have R changed value and this common issue at PW_ON or T-CON12_ON.. also the other common issue optocoupler.
                    • EazyBone
                      • Jun 2023
                      • 1347
                      • United states
                      Is this the optocoupler you are talking about? Is there a way to test it? Gonna research it
                        • 12206
                        • U.S.
                        Opto is PC6201.
                        • EazyBone
                          • Jun 2023
                          • 1347
                          • United states
                          Long time no see Sony, know of how I can test it? It's this in the picture right?
                          • Diah
                            • Feb 2013
                            • 6397
                            lol..... this is transformer.. the opto the ic with 4 pin close to it down
                            • Diah
                              • Feb 2013
                              • 6397
                              from the mistake above, i suggest you to test the t-con and panel as stand alone if they are fine then buy PSU
                              you test before BL on and power On which you have 12V to MB ---- use this 12V to test T-con... MB should be disconnected from PSU and T-CON also, t-con 12V socket need to be disconnected too from PSU
                              note t-con need to have the - too... because u will disconnect the sockt
                              • EazyBone
                                • Jun 2023
                                • 1347
                                • United states
                                I just saw the optocoupler on a video and researching it. He used compress air to freeze it and it started working, just saw what it is now. Thanks.
                                Okay diah. TCON needs to have - too? What does this mean. It needs grounded is what your saying?
                                So the PSU supplies 3 12v wires to tcon, do I need to connect each wire to the 12v? But this will happen tonight! Awesome.
                                Appreciate all the effort you put into these posts diah, thanks.
                                Others as well.
                                • lotas
                                  • Jan 2016
                                  • 4658
                                  • Russia
                                  This clearly shows that the problem is with the motherboard.
                                  • Diah
                                    • Feb 2013
                                    • 6397
                                    No Lotas.... the T-CON12V come from PSU not from MB... and when he do PSU stand alone test ...PW_ON are fine 12V to MB exsisit and BL_on also BL tuen on... only T-con12V_on have low voltage 2.6V
                                    Others as well.
                                    1- the socket between T-COB and PSu disconnected
                                    2- MB disconnected to PSU and LVDS to T-CON too
                                    3- just do PSU stand alone STB to PW-ON and STB to BL-ON as you did before
                                    the 12V the PSU generated to MB use it to T-CON...if u have Fuse put it on it...
                                    just think we are disconnecting the socket of 12V from T-con and PSU... so the GND chassis line will be disconnected.... so we need to do it in case the t-con have no GND
                                    • lotas
                                      • Jan 2016
                                      • 4658
                                      • Russia
                                      The backlight does not start (there is no command from the motherboard, 12v is not supplied to the T-con, there are no indicators, there is no sound in the speakers... and what could it be?
                                      • Diah
                                        • Feb 2013
                                        • 6397
                                        lotas... are you under drinking.. or mixed with other threat.... read this threat first post lol
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • maxim2511
                                          LG 55EC930V OLED - swich on swich of no screen
                                          by maxim2511
                                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                          Then I get an idea to take it apart and clean boards from dust.
                                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                          05-14-2021, 02:21 AM
                                        • stylishconsultant
                                          un60j620dafxza - Samsung No Display Problem
                                          by stylishconsultant
                                          Hi All,
                                          Need help.
                                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                          09-04-2024, 03:26 AM
