xr-55x90j power issue
  • lotas
    • Jan 2016
    • 4455
    • Russia
    Re: xr-55x90j power issue
    Originally posted by Diah
    lotas... are you under drinking.. or mixed with other threat.... read this threat first post lol
    I'm sober, did you mention that in the first post?
    -"I have checked the PSU and it feeds 12v to main board and correct voltage to the LED driver.
    I have forced the backlights on and they work through the PSU."
    • Diah
      • Feb 2013
      • 6339
      yes but on the PSu socket also there are pins T-CON12V-ON... when he connect it to STB he got low V round 2.6 here where i am talking
      • EazyBone
        • Jun 2023
        • 1303
        • United states
        @diah I did the test, added ground pin to tcon for safety and screen goes white green blue red. Panel is okay. BL come on all is well. So tcon and panel are good, LED driver good.
        Leaves psu and main.
        Clearly PSU won't supply 12v to tcon and that's an issue. Gonna reread everything first and look at this fresh tomorrow.
        @lotas, I thought the same thing with main board. But tcon 12v throwing me off. PSU seems to supple tcon 12v and I cannot force 12v on it so I'm interested in why. But I also thought main was cause also. We will see soon.
        At least panel and tcon are good! Yay!
        Also to add to first post, it appears the .178 is not being supplied to tcon from main board but is the voltage from PSU to tcon. Whatever voltage coming from PSU to tcon is the voltage the tcon gets at the fuse
        Edit: not sure if measuring with ground to chassis means anything but one side octocoupler reads 10.37other 9.33. just throwing that data here.
        I also tried freezing it as the video I saw showed and no change, same voltages.
        • R_J
          • Jun 2012
          • 9514
          Your T-con 12 volts comes from the REG12V and is switched by U6? (can't make out the number) mosfet on the power supply to provide the TCON_12V, are you getting the TCON_ON voltage (CN6401, Pin 26) from the main board?
          • Diah
            • Feb 2013
            • 6339
            good news, but now you need to take out the PSU amd leave it always standalone on the table with primary jumper connect BTW STB-PW-On & STB -T-CON12ON
            upload high resolution Photo of the TOP & down side to help us read the diagram of the T-COn 12 circuit.. its easy task now
            i wrote to take it out... in-order don't plug the MB to it.... we don't want any damage could happen to MB if there short at the circuit on PSU
            • EazyBone
              • Jun 2023
              • 1303
              • United states
              #26
              I don't understand what's going on, badcaps has changed it's entire setup for me and replies are gone, like everything is messed up for me
              • lotas
                • Jan 2016
                • 4455
                • Russia
                #27
                It’s just that after changing the engine and interface, the latest messages were not saved and personal messages disappeared!
                • EazyBone
                  • Jun 2023
                  • 1303
                  • United states
                  #28
                  Well that's sucks. I personally don't like this new interface. Old one was amazing this one is just unfriendly.
                  • nomoresonys
                    • 12075
                    • U.S.
                    #29
                    +1000 Agree, this new setup sucks balls, had to add a picture, just to see which posts were mine, wish there was a choice between this and the old/better one.
                    • EazyBone
                      • Jun 2023
                      • 1303
                      • United states
                      #30
                      Well this was main board issue. TCON on through power board alone will not turn on 12v for this model alone without MB I guess. Fixed!
                      • lotas
                        • Jan 2016
                        • 4455
                        • Russia
                        #31
                        Well, what I said was that the problem was in the motherboard, but someone argued that the problem was in the power supply.
                        • EazyBone
                          • Jun 2023
                          • 1303
                          • United states
                          #32
                          Yes, which was what I originally thought as well, but more of just a guess. Why the PSU won't turn on Tcon12v like other psus from Sony beats me.
                          • lotas
                            • Jan 2016
                            • 4455
                            • Russia
                            #33
                            But apart from these 12 volts, there was no indication, no backlight, no sound, although the power supply supplied 12 V to the motherboard.
                            • Dani_2024
                              by Dani_2024
                              10-28-2024, 05:06 PM
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • Asraf Atb
                              Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                              by Asraf Atb
                              Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                              Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                              I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                              01-27-2025, 05:02 PM
                            • maxim2511
                              LG 55EC930V OLED - swich on swich of no screen
                              by maxim2511
                              My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                              Then I get an idea to take it apart and clean boards from dust.
                              In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                              Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                              05-14-2021, 02:21 AM
                            • stylishconsultant
                              un60j620dafxza - Samsung No Display Problem
                              by stylishconsultant
                              Hi All,
                              Need help.
                              I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                              So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                              problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                              might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                              09-04-2024, 03:26 AM
