LG 55UH7650-UA needs a capacitor!
  • x_orange90_x
    • May 2015
    • 727
    Re: LG 55UH7650-UA needs a capacitor!
    I checked the fuse. It's showing .28v with the power on. The other fuse on the board stays at 0v.
    • lotas
      • Jan 2016
      • 4753
      • Russia
      Fuses are checked for resistance with a multimeter; a working fuse should show a short circuit!
      • x_orange90_x
        • May 2015
        • 727
        When I set it to Ohms it bounced around all over the place. DigiKey's website recommends checking voltage for a fuse that's in-circuit. A working fuse should show 0v.
        Is .28v an indicator that the fuse is bad? Or is that close enough to 0 that it's good?
        • lotas
          • Jan 2016
          • 4753
          • Russia
          You need to unplug (de-energize) the TV from the outlet, and then measure the resistance of the fuses.
          • x_orange90_x
            • May 2015
            • 727
            I will recheck this later. Thanks.
            • x_orange90_x
              • May 2015
              • 727
              I checked it and I get 1.000 both ways. My meter only has one ohms setting so that's what I used. The other fuse read good.
              • lotas
                • Jan 2016
                • 4753
                • Russia
                #27
                As I thought, it was this one that burned down?
                • x_orange90_x
                  • May 2015
                  • 727
                  Yep. The one with the red stripe. Question though, do 125v and 250v fuses have to be checked differently? I checked another suspected good 250v fuse and it also read 1.000, but when I checked a 125v it tested good. Meter is set to AC and Ohms (the only seeing I have).
                  • lotas
                    • Jan 2016
                    • 4753
                    • Russia
                    #29
                    Any serviceable, working fuse should show 0 Om on the multimeter; a faulty, non-working fuse will not show anything.
                    • x_orange90_x
                      • May 2015
                      • 727
                      So the first thing I should do now is replace that fuse and see what happens? All I have on hand is the one I tested that was the correct fuse but also showed 1.000, and a couple 7.5A 250v. Would it not be a good idea to replace a 5A with a 7.5A?
                      • lotas
                        • Jan 2016
                        • 4753
                        • Russia
                        #31
                        At this point, this is not the best option, since mosfets and diodes have not been tested, it is better to use a 100W incandescent lamp instead of a fuse for testing; if the power supply works, then install a regular 5A fuse.
                        • x_orange90_x
                          • May 2015
                          • 727
                          I've heard of the light bulb thing but I've never done it. How would I connect it in place of the fuse? Incandescent bulbs were banned in the US a few months ago. I may have a 100w, or possible a 3 way. Otherwise I think all i have is 60w.
                          • lotas
                            • Jan 2016
                            • 4753
                            • Russia
                            #33
                            Solder a lamp socket with two wires into the place of the fuse or solder it on top to the ends, try at 60w, if not at 100w.
                            • x_orange90_x
                              • May 2015
                              • 727
                              Ok. When I plug it in the bulb shouldn't light if the circuit is closed (no bad components), correct? Lights up = bad?
                              • lotas
                                • Jan 2016
                                • 4753
                                • Russia
                                #35
                                Yes, it should not burn; when turned on, it should flare up a little and go out.
                                • x_orange90_x
                                  • May 2015
                                  • 727
                                  Does it matter which wire goes where in regards to positive and negative?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #37
                                    no does not matter
                                    • lotas
                                      • Jan 2016
                                      • 4753
                                      • Russia
                                      #38
                                      The fuse does not have a positive or negative terminal, and neither does the lamp!
                                      • x_orange90_x
                                        • May 2015
                                        • 727
                                        I did not think so. I'll tackle this tonight and report back my findings. Thanks a lot for the help!
                                        • x_orange90_x
                                          • May 2015
                                          • 727
                                          Results are in... The bulb stays lit ��
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
