Hisense 75R63E backlight help
  • TVGuy419
    • Oct 2023
    • 10
    Hey everyone. Hoping someone has some insight as to what may cause brand new backlights look like this behind the diffuser sheet. I've done about 40 TVs and never seen anything like this. Any help is appreciated as this shows through to the picture during lighter color scenes.
  • Diah
    • Feb 2013
    • 6360
    Re: Hisense 75R63E backlight help
    flip the first solid plate... the smooth surface should be on top
    • TVGuy419
      • Oct 2023
      • 10
      I flipped it every way possible and still looks the same. I can actually see dark spots through the diffuser lense when the bulbs are off. Seems odd.
      • Diah
        • Feb 2013
        • 6360
        now are different from first photo.... put the reset and see the result
        • TVGuy419
          • Oct 2023
          • 10
          First photo is with backlights turned on and second one is with them off showing the dark spots where each LED is behind the diffuser. With them on, I get the same halo effect no matter how the diffuser is installed.
          • Diah
            • Feb 2013
            • 6360
            you did replaced LED BL many time as you wrote... the first Solid Plate had 2 surface.... one with small bubble and other smooth... smooth always on the top facing the rest sheets and LCD... no need to do try... if there are black sport on it, exam them if they are burn or dirty. this is strange.. also be sure the legs stand pieces are straight so this plate will sitting straight. as well the first reflector white paper should be mounted tight to the chassis.
            • Diah
              • Feb 2013
              • 6360
              BTW the white reflector paper... did have black circle round the LED places... could be this what you are see.
              • EazyBone
                • Jun 2023
                • 1320
                • United states
                Yup I've had this happen also. I had a panel issue, so I just tossed the TV but is basically same thing. I know for certain the diffuser was the correct way. When I put tv back together though I tore a ribbon off the panel lol and ruined it. I never decided to investigate further. I don't have an answer either, and for me it was only in the central area of screen as you see.
                • TVGuy419
                  • Oct 2023
                  • 10
                  Think I could have received bad LEDs? Seems to me that the light is coming out around the plastic caps and not out the top toward the diffuser. Could be wrong but that's what I see. This is a picture with the diffuser sheets removed but white paper in place.
                  • Diah
                    • Feb 2013
                    • 6360
                    the original LED lens was Concave as the replacement or they were Convex !!!
                    • TVGuy419
                      • Oct 2023
                      • 10
                      Both are concave.
                      • Diah
                        • Feb 2013
                        • 6360
                        Both are concave.
                        feed the TV with signal that you will hear sound... then the LED currents will turn High... it may now low currents cause no LCD in place and no video signal.. better put the solid plate as described in order and try.
                        • TVGuy419
                          • Oct 2023
                          • 10
                          I had the TV back together and watched a football game on it. You can clearly see the LEDs on all light colored scenes. Darker colors look great. Messed with backlight and brightness which really didn't change anything.
                          • Diah
                            • Feb 2013
                            • 6360
                            check psu bl currents...
                            • EazyBone
                              • Jun 2023
                              • 1320
                              • United states
                              I'm probably not a solution but the paper sheet is pushed down as far as possible? Generally they are taped down. Also, maybe the picture is to the side but are the LED caps off center? The picture shows them maybe sideways slightly, could be angle of cap.
                              Very curious myself because why did I have the problem only on part of one of my screens also lol.
                              • Diah
                                • Feb 2013
                                • 6360
                                LED lens fitting by Robot. with Laser position sensor,, no way for mistake..
                                LEDs if its specification higher as original will make shadow. same if the PSU current are low as it should... other reasons the order of the sheets.
                                • EazyBone
                                  • Jun 2023
                                  • 1320
                                  • United states
                                  https://www.reddit.com/r/TVRepair/co...rough_display/
                                  Here's a post with similar tv. He may have lost a diffuser sheet.
                                  • TVGuy419
                                    • Oct 2023
                                    • 10
                                    I kept the diffuser sheets taped together so I didn't mess them up during installation. Really starting to lean toward crap replacement LEDs. I can't see the reflective paper causing uniform halos like this.
                                    • EazyBone
                                      • Jun 2023
                                      • 1320
                                      • United states
                                      Hey I can't either. I'm just throwing a bunch of possibilities. I've had a diffuser sheet slide off the top before on something unstable. This happened in my picture also only on part of the screen.
                                      I once forgot to put all the diffusers back and put the TV and screen back together lol dumb mistake. The screen looked very cool after I turned it on lol
                                      • ojmc
                                        Hisense 65H6570G - Color inverted after replacing LED backlight
                                        by ojmc
                                        Background:
                                        • Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
                                        • I replaced all 6 of the backlight LED strips with these replacements: amazon
                                        • The TV worked again perfectly for ~2 weeks.
                                        • After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
                                        10-17-2024, 02:29 PM
                                      • triplefour
                                        by triplefour
                                        09-13-2023, 10:43 PM
                                      • Mschrenkz@gmail.com
                                        Hisense 60R6E - No backlight - stuck in boot loop
                                        by Mschrenkz@gmail.com
                                        I joined hoping I'll be able to verify which component I need to replace on my Hisense 60R6E. When I plug it in the red light comes on and stays on for several seconds then blinks off and then on again. There is no back light but I can see the logo screen "Hisense Roku" (using the flashlight method) come on while the red light is off. Then it dissapears and the red light is constant again. This cycle keeps repeating. I tried pressing the reset button and it has absolutely no impact. Even held it in for 30 seconds also tried holding the power button in with the TV unplugged - nothing...
                                        05-09-2023, 08:53 AM
                                      • DanPoka
                                        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                        by DanPoka
                                        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                        02-15-2025, 05:05 AM
                                      • Comp_Pro
                                        No Backlight Macbook A1990 820-01041
                                        by Comp_Pro
                                        Hello all,
                                        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                        Tests performed:
                                        There is no backlight even with a good screen.
                                        Backlight IC is receiving the correct support voltages.
                                        Fuse F8400 ok
                                        Current sense resistor R8400 ok
                                        Backlight IC is receiving 3.3V on enable pin.
                                        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                        Backlight IC receiving 5V from PP5V_G3S
                                        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                        05-06-2024, 10:23 PM
