qn75q70rafxza suiciding samsungs
  • EazyBone
    • Jun 2023
    • 1347
    • United states
    #61
    Picked up another of these. Just noting that it was the LED driver again. 3.3v was absent from led driver again.
    Not sure why it's so hard to search on bad caps now. Took forever to find this thread.
      • 21173
      Did you put the model number into the search https://www.badcaps.net/search?q=qn7...70rafxza%22%7D
      • EazyBone
        • Jun 2023
        • 1347
        • United states
        #63
        See that's the thing. I didn't know I put fxza at the end. If you don't and just put beginning part, it won't find it.
          • 21173
          The search isn`t working for partial filenames. The old forum software search function worked better IMO .
            • 12206
            • U.S.
            #65
            Got a question, did they change up the how signature works or rename it? not seeing it anywhere.
              • 21173
              User settings, Account tab , Edit post signature
              • EazyBone
                • Jun 2023
                • 1347
                • United states
                #67
                This is what I'm saying! How would any random know to search for FULL name or not. It's a bit ridiculous because before I could search for partial and would get hits. It bothers me because I can't find my own topics
                  • 12206
                  • U.S.
                  #68
                  Thanks, you're not too bad of a chap, for a moderator.
                    • 12206
                    • U.S.
                    #69
                    Indeed, it use to be easy to find your own threads, I don't see it now tho.
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • ygorsan
                      by ygorsan
                      🧩 Problem Summary:
                      • I
                      07-28-2025, 08:34 AM
                    • Asraf Atb
                      by Asraf Atb
                      01-27-2025, 05:02 PM
                    • JSin21
                      Compatibility of main boards between different variations of samsung MU6100
                      by JSin21
                      Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                      I have Samsung Smart TV UA65MU6100WXXY version DA01
                      Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                      11-27-2023, 04:54 AM
                    • mkdj
                      Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                      by mkdj
                      Dear all,
                      I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                      I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                      Both N-Channel Mosfets: nothing odd
                      P-Channel MOSFET number 1:
                      source - drain : 117 kOhm
                      source - gate: 96 Ohm
                      gate - drain: 117 kOhm
                      P-Channel MOSFET...
                      08-20-2025, 06:08 AM
