qn75q70rafxza suiciding samsungs
  • EazyBone
    • Jun 2023
    • 1356
    • United states
    #61
    Picked up another of these. Just noting that it was the LED driver again. 3.3v was absent from led driver again.
    Not sure why it's so hard to search on bad caps now. Took forever to find this thread.
      • 21857
      Did you put the model number into the search https://www.badcaps.net/search?q=qn7...70rafxza%22%7D
      • EazyBone
        • Jun 2023
        • 1356
        • United states
        #63
        See that's the thing. I didn't know I put fxza at the end. If you don't and just put beginning part, it won't find it.
          • 21857
          The search isn`t working for partial filenames. The old forum software search function worked better IMO .
          • nomoresonys
            • 12305
            • U.S.
            #65
            Got a question, did they change up the how signature works or rename it? not seeing it anywhere.
              • 21857
              User settings, Account tab , Edit post signature
              • EazyBone
                • Jun 2023
                • 1356
                • United states
                #67
                This is what I'm saying! How would any random know to search for FULL name or not. It's a bit ridiculous because before I could search for partial and would get hits. It bothers me because I can't find my own topics
                • nomoresonys
                  • 12305
                  • U.S.
                  #68
                  Thanks, you're not too bad of a chap, for a moderator.
                  • nomoresonys
                    • 12305
                    • U.S.
                    #69
                    Indeed, it use to be easy to find your own threads, I don't see it now tho.
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • ygorsan
                      by ygorsan
                      🧩 Problem Summary:
                      • I
                      07-28-2025, 08:34 AM
                    • Asraf Atb
                      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                      by Asraf Atb
                      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                      01-27-2025, 05:02 PM
                    • semiRocket
                      Toshiba 37bv701b power supply main rails
                      by semiRocket
                      The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
                      I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
                      Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
                      10-26-2025, 01:55 AM
                    • JSin21
                      Compatibility of main boards between different variations of samsung MU6100
                      by JSin21
                      Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                      I have Samsung Smart TV UA65MU6100WXXY version DA01
                      Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                      11-27-2023, 04:54 AM
