qn75q70rafxza suiciding samsungs
  • lotas
    • Jan 2016
    • 4787
    • Russia
    #41
    Re: qn75q70rafxza suiciding samsungs
    What is the general resistance between 1(3.3v) and 4(GND), is it not low?
    • EazyBone
      • Jun 2023
      • 1356
      • United states
      #42
      Originally posted by Diah
      well every things possible... he can use cool spray to freeze it.... then turn on... if the 30 second BL on increase... if so will be funny case
      Bl doesn't come on at all anymore, not even 30 sec.
      What would I try to freeze?
      Lotas 2.4kohm 1 and 4
      • Diah
        • Feb 2013
        • 6468
        Pt9801
        • Diah
          • Feb 2013
          • 6468
          or try by pass it with short circuit..
          • lotas
            • Jan 2016
            • 4787
            • Russia
            #45
            You need to determine how and what is assembled on these three channels, what voltages they have at their terminals, and what transistors they are.
            • EazyBone
              • Jun 2023
              • 1356
              • United states
              #46
              Will do lotas, will report back in about 4 hours
              • Diah
                • Feb 2013
                • 6468
                one things more.. if PT9801 (a PTC Thermistor as we thought ) and there swollen at the middle of the surface it will be in cutoff always.
                • EazyBone
                  • Jun 2023
                  • 1356
                  • United states
                  #48
                  Pt9801 has 3 ohms resistance so multi meter shows short because almost no resistance
                  There is 1.408 v coming in and 1.408v leaving
                  • Diah
                    • Feb 2013
                    • 6468
                    1.408v you have also on pin 1 9802 ?
                    • EazyBone
                      • Jun 2023
                      • 1356
                      • United states
                      #50
                      Yup
                      Pin 1 shows continuity to both right and left side of pt9801 it shows no resistance continuity on right side on left side it shows 3 ohm resistance so almost continuity just low resistance. All 3 points show 1.408 v
                      • Diah
                        • Feb 2013
                        • 6468
                        Originally posted by EazyBone
                        Yup
                        did you read my post #56 ??
                        you need to free one leg of PT9801... to let Pin 1 zero V. and then we feed Pin 1 with 3.3V... i wrote an example... but you can use any source on TV like power on.... but in this case need to connect it via R 1K
                        • EazyBone
                          • Jun 2023
                          • 1356
                          • United states
                          #52
                          So can I just pull pt9801 off the board then feed pin 1 the 3.3v? I don't know how to free it otherwise. And I will need to buy some resistors I see you say jump 3.3v with 1k all the time but I don't have one. Maybe scrap board. Okay will try tonight
                          • Diah
                            • Feb 2013
                            • 6468
                            sure you can take it out... but dont lost it..lol... after take it out u need to test to see the v you read before on which side in and if pin 1 ready to be 0v.
                            • EazyBone
                              • Jun 2023
                              • 1356
                              • United states
                              #54
                              Okay I didn't get into all the exactness of it but installed new led driver board and it's working fine. Points 1 and 2 as established run at 3.1v as picture shows.
                              Thx story, lotas and diah and anyone I may of missed.
                              • Diah
                                • Feb 2013
                                • 6468
                                • lotas
                                  • Jan 2016
                                  • 4787
                                  • Russia
                                  #56
                                  why you sold it to him,,, at time you can install power boards and main boards on yours ??? just the LED socket need new configuration at wiring !!
                                  Diah, what are you talking about?
                                  • Diah
                                    • Feb 2013
                                    • 6468
                                    lol.... wrong
                                    • EazyBone
                                      • Jun 2023
                                      • 1356
                                      • United states
                                      #58
                                      Yes lol diah.
                                      • Diah
                                        • Feb 2013
                                        • 6468
                                        Yes lol diah.
                                        No, i post 2 time over here... but they were thought to another threat.... Lotas give me the attention so i delete them.
                                        • KYBOSH
                                          • Oct 2011
                                          • 581
                                          • Unknown
                                          #60
                                          I would love to know what was wrong on the old board.
                                          Not sure if you buttoned up this TV yet but if not (and it were me) I would be probing and comparing to see where the fault was. An SMD or an IC.
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • ygorsan
                                            by ygorsan
                                            🧩 Problem Summary:
                                            • I
                                            07-28-2025, 08:34 AM
                                          • Asraf Atb
                                            by Asraf Atb
                                            01-27-2025, 05:02 PM
                                          • semiRocket
                                            Toshiba 37bv701b power supply main rails
                                            by semiRocket
                                            The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
                                            I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
                                            Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
                                            10-26-2025, 01:55 AM
                                          • JSin21
                                            Compatibility of main boards between different variations of samsung MU6100
                                            by JSin21
                                            Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                            I have Samsung Smart TV UA65MU6100WXXY version DA01
                                            Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                            11-27-2023, 04:54 AM
