Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
  • kca
    • Feb 2016
    • 548
    Re: Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
    Quick question:
    I'm getting 5.7v on the PS connector that leads over to the main board. So that is fine. But when I pulled the two other connectors on the PS that both lead directly to the panel itself I get 0.0v on every pin.
    Does that mean that the PS is not providing voltage to these connectors or could it mean that the tv senses the connectors have been pulled and it then automatically denies voltage at the PS level so that it never reaches the connectors in a purposeful way as the tv tries to protect itself?
    • kca
      • Feb 2016
      • 548
      Wondering if anyone can provide an answer to that last question as it pertains to this particular model of television (Samsung UN60F8000BFXZA).
      I’m trying to determine if the LED panel itself has stopped working as opposed to the Power Supply board being the culprit.
      ~ kca
      • kca
        • Feb 2016
        • 548
        Given the pictures I posted earlier, does anyone know how I can safely force the backlights on re: this particular model Samsung tv?
        I would like to prove or disprove that the backlights are still functional. What would be the exact steps that it would take to jump them on?
        ~ kca
          • 12307
          • U.S.
          It's a samsung, if you unhook the cable from powerboard to maqinboard, leave it off, plug power cord into wall if backlights do not come on and stay on there's problem before the mainboard, meaning problem in the powerboard or backlight/backlight circuit, if they don't come on wiggle the wiress a little going from powerboard to panel, just to check if there's a problem there.
          • kca
            • Feb 2016
            • 548
            Yes, that is what I established a few days ago. No backlights appear. So now I’m trying to determine if the backlights are indeed functional before I either replace components on the PS board or just buy a new PS.
            I can get a power supply board for only $42, but I want to prove that the backlights are operational before considering the PS purchase. I’ve read several posts that explain that the backlights can often be jumped on but I don’t know exactly which pins / resistors / boards to employ. Or, maybe none of that would work given the current symptoms? That’s what I don’t know but would like to try if it’s doable.
            ~ kca
              • 12307
              • U.S.
              #26
              Can you post a good clear picture of the legend/map of the connector there, looks like the one on the corner of the board.
              • lotas
                • Jan 2016
                • 4803
                • Russia
                #27
                This trick does not work on some models.
                  • 12307
                  • U.S.
                  #28
                  Does it on this one, can you tell if it has pull up resistors?
                  • lotas
                    • Jan 2016
                    • 4803
                    • Russia
                    #29
                    I don’t remember on this model and I don’t have it for repair now.
                    • Storyteller12
                      • Jun 2020
                      • 625
                      Yes, it works on this model also.
                      • lotas
                        • Jan 2016
                        • 4803
                        • Russia
                        #31
                        This model (xxF8000) does not have a simple power supply; it has a built-in programmed controller that controls the backlight.
                          • 12307
                          • U.S.
                          #32
                          Ok, interesting, I'm not familiar with this one, wonder if the force on is basically the same as most?
                          • kca
                            • Feb 2016
                            • 548
                            Here are the pertinent images of the PS board we're discussing:
                            Photo #1 = Entire PS
                            #2 = top left (primary) connector voltage chart
                            #3 = middle left connector chart (heads out directly to one of two LED cables)
                            #4 = bottom left connector chart (heads out directly to the other LED cable)
                            #5 = image of the two “twin” LED cables themselves
                              • 12307
                              • U.S.
                              #34
                              Ok, take it slow, #2 with cable from powerboard to mainboard unhooked, check the pins voltage 1-27 can skip grounds, which pins have voltage and how much.
                              • kca
                                • Feb 2016
                                • 548
                                Yes, it appears this model’s PS is designed to supply voltage directly to these dual LED cables via the two connectors. As I mentioned in an earlier post, the readings on both the middle left LED connector and the bottom left LED connector are 0.0 on all of those pins.
                                In other words, it appears that the PS is failing to supply these LED connectors and cables with the necessary voltages. But, could it also be that the failure of the backlights themselves might cause the voltages to be denied to these two LED connectors because the tv recognizes the backlights are not functioning (or not functioning properly) and it therefore denies voltage to the LED cables because it’s attempting to protect itself from further damage?
                                This is why I’m trying to fire up the backlights in any other, logical way to prove to myself that the backlights are not the problem and that the PSU, definitively, is the issue.
                                  • 12307
                                  • U.S.
                                  #36
                                  We can try it, if you make sure you use resistors for the connections you shouldn't blow anything up.
                                    • 12307
                                    • U.S.
                                    #37
                                    Do post #34 first.
                                      • 12307
                                      • U.S.
                                      #38
                                      Here's a good video from Bobby, might help, see if you can understand it: https://www.youtube.com/watch?v=qIue5Sd6fzE
                                      • kca
                                        • Feb 2016
                                        • 548
                                        Okay. I’ll check them all again and list them in the next post.
                                        In my original post, I didn’t make it perfectly clear but I had tested all of these pins (1 through 28) and the only one I found suspect was that SDA line I was discussing earlier in the thread. I’ll post exact voltages for all 28 pins to help clarify all of that.
                                        • lotas
                                          • Jan 2016
                                          • 4803
                                          • Russia
                                          #40
                                          This is a plasma power supply, it's completely different and it doesn't have a backlight.
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
