Hi guys as you can see on the picture I have problem with this tv there are some vertical lines on the display, so the problem is t-con board or some short on the board of the panel but I don't know where to start. Thank you for the answer! Ah I never doing some tests for this problem, any help is welcome Thank you again
Smart tv Smarttech SMT43N30FV1U1B1 line on the screen.
Re: Smart tv Smarttech line on the screen.
Hi thank you, but it doesn't explain anything about t-con board but only power supply board.Comment
Re: Smart tv Smarttech SMT43N30FV1U1B1 line on the screen.
What it says among other things, IS help us to help you, by posting good focused straight on pictures of every board and one of the whole back as to see how everything is connected.Comment
Oh I'm sorry for misunderstanding and thank you for your reply, in the meantime I checked some things and with a temperature laser gun (I don't have a termal camera) I found a side (marked with white colour)with the temperature growing up about 60/70-75
Maybe is that component the problem?thank you again.Attached Filesif you find these attachements useful please consider making a small donation to the site
Maybe try cleaning the 2 tcon ribbon cable pins with ipa, some use pencil eraser, not too vigorously they can be fragile, inspect and make sure none of the pins are damaged and make sure the lvds cable is clean and secure at the tcon, maybe try a replacement tcon, they usually aren't too expensive.Comment
Hi, thanks for your reply qbut it's too late, I give it back to his owner. Anyway I have been checked all of cable and they was good.Maybe try cleaning the 2 tcon ribbon cable pins with ipa, some use pencil eraser, not too vigorously they can be fragile, inspect and make sure none of the pins are damaged and make sure the lvds cable is clean and secure at the tcon, maybe try a replacement tcon, they usually aren't too expensive.Comment
by KibergeHI guys!
I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by almarhumHas one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...-
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... - Loading...
