Smart tv Smarttech SMT43N30FV1U1B1 line on the screen.
  • labello
    • Mar 2018
    • 252
    • italia
    Hi guys as you can see on the picture I have problem with this tv there are some vertical lines on the display, so the problem is t-con board or some short on the board of the panel but I don't know where to start. Thank you for the answer! Ah I never doing some tests for this problem, any help is welcome Thank you again
  • labello
    • Mar 2018
    • 252
    • italia
    Re: Smart tv Smarttech line on the screen.
    Hi guys, I've tried to find a schematic of t-con board but I don't have any lucky. Anyone here can help me? Thank you so much ��
      • 12187
      • U.S.
      https://www.badcaps.net/forum/showthread.php?t=39740
      • labello
        • Mar 2018
        • 252
        • italia
        Hi thank you, but it doesn't explain anything about t-con board but only power supply board.
          • 12187
          • U.S.
          Re: Smart tv Smarttech SMT43N30FV1U1B1 line on the screen.
          What it says among other things, IS help us to help you, by posting good focused straight on pictures of every board and one of the whole back as to see how everything is connected.
          • labello
            • Mar 2018
            • 252
            • italia
            Oh I'm sorry for misunderstanding and thank you for your reply, in the meantime I checked some things and with a temperature laser gun (I don't have a termal camera) I found a side (marked with white colour)with the temperature growing up about 60/70-75
            Maybe is that component the problem?thank you again.
              • 12187
              • U.S.
              Maybe try cleaning the 2 tcon ribbon cable pins with ipa, some use pencil eraser, not too vigorously they can be fragile, inspect and make sure none of the pins are damaged and make sure the lvds cable is clean and secure at the tcon, maybe try a replacement tcon, they usually aren't too expensive.
              • labello
                • Mar 2018
                • 252
                • italia
                Hi, thanks for your reply qbut it's too late, I give it back to his owner. Anyway I have been checked all of cable and they was good.
                • Kiberge
                  Samsung LH82QENELGC/EN Help needed - Static line on screen
                  by Kiberge
                  HI guys!
                  I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                  I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                  the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                  This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                  04-22-2024, 11:28 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • almarhum
                  To fix laptop screen vertical line by working on its EDP cable
                  by almarhum
                  Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                  As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                  05-07-2024, 02:12 PM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
