Sony KD-55XG8796 No power
  • matyka
    • Jan 2015
    • 179
    • Uk
    I have been given a Sony KD-55XG8796 with no power no lights. I have done some measurements and I found diode SB260 shorted D950A position on the board.
    I have replaced with SR260 and TV came up to life.
    • 12328
    • U.S.
    Re: Sony KD-55XG8796 No power
    Nice work, sometimes it's something pretty simple, that's why I ALWAYS check those things first: https://www.youtube.com/watch?v=AynXoLjYrKc
    • brianbelfast
      • Jun 2010
      • 29
      • Northern Ireland
      Nice story from my past.... About 30 years ago. A friend of mine had a cassette deck which was low on one channel. He couldn't figure it out. He had signal tracers and oscilloscopes on the job and he'd even replaced a transistor and the dolby IC on the bad channel but the fault remained. As soon as he let me hear it going, I wet my finger and wiped the play head. Fault gone. He was pleased and angry at the same time lol.
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • PopsCaps
        Sony Bravia KDL-40V2500 that will not power on
        by PopsCaps
        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
        I do not hear any sound and I cannot see any backlight.
        I have tried disconnecting every cable on each board one at a time to see if anything changes.
        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
        03-25-2025, 11:23 AM
      • noinimod
        Sony 55X900E no standby light, no power. Replaced mainboard already
        by noinimod
        No standby red light, nothing
        This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
        Disconnected JK3 power board from main board, checked voltages on all the pin outs
        At a few pins I can see the power supply providing 19.5V to the main board
        Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
        LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
        12-22-2021, 12:58 AM
      • bcstedt
        LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
        by bcstedt
        LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
        Problem:
        On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
        It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
        01-18-2024, 01:03 PM
