Sony xbr-75x900f 6 red blink
  • Diah
    • Feb 2013
    • 6357
    Re: Sony xbr-75x900f 6 red blink
    full LED / Local Dimming , working principle like Philips Ambilight but here BL , the MB firmware with X engine sock will defined the Picture color position to code like MAC. this mean.. at start up Sony Logo will be only middle position LED BL lit on.. this mean too the other LED ribbon cable can be disconnected.. because no signal of MAC code will go to them, try disconnect LEDs cable one by one to notice any change at start up
    • nomoresonys
      • 12099
      • U.S.
      #42
      Originally posted by EazyBone
      Literally anything. Pb to main, backlight error which still exists. Second pb voltages every is negative lol
      Test something else to make sure it's not your meter acting up, this is strange indeed.
      • EazyBone
        • Jun 2023
        • 1309
        • United states
        #43
        Will try this !
        Lol Sony I posted earlier, was a bit tired and just switched red and black on meter ����
        Diah, so they cables and LED are numbered from one starting at the bottom and go up to 12.
        So essentially since the logo is middle screen I would essentially try disconnecting for example like 4-8 one at a time. Since they'd go on for the Sony logo. Gonna try it this way and every way.
        • nomoresonys
          • 12099
          • U.S.
          #44
          Maybe test those little ceramic caps on your blue/ld/backlight driver board, check for shorts or very low ohms.
          • nomoresonys
            • 12099
            • U.S.
            #45
            Here's Nick checking the dps board/backlight driver board on a sony, he has voltage going in but not coming out of board, so he knows it's that board that's faulty: https://www.youtube.com/watch?v=kaCl8J1pPd8
            • nomoresonys
              • 12099
              • U.S.
              #46
              Will try this !
              Was my first thought but figured no he couldn't possibly be doing that.
              • EazyBone
                • Jun 2023
                • 1309
                • United states
                #47
                I'm gonna watch that video right now.
                Is this N thing a fuse also? Looks like one to me, no continuity on it.
                • nomoresonys
                  • 12099
                  • U.S.
                  #48
                  • Storyteller12
                    • Jun 2020
                    • 624
                    Have you replaced the backlights with new strips?
                    If the screen is still out you can unplug the lvds cable going to the blue board and power up the tv. It should cycle the backlights in a test pattern. If backlights are all good they stay lit after the test. If bad they will cut off after test.
                    I usually record a video of the test pattern so I can watch and see what led is not working. Usually it’s only 1 led that causes the error.
                    Sonys are very finicky with the voltage and current the leds draw. I tried to temporarily wire 4 3v leds to test the one light out and still got the error untill I replaced with 1 12v led for Sony TVs
                    • nomoresonys
                      • 12099
                      • U.S.
                      #50
                      My bad, I thought you were highlighting the fuse, just now saw the N component.
                      • EazyBone
                        • Jun 2023
                        • 1309
                        • United states
                        #51
                        Backlights are new strips. New ones and old ones all tested fine with LED tester. When I tested them all with LED tester they were all working properly (but LED tester as people said may be unreliable) but they all lit up. Replaced them anyways just because.
                        And story, do you mean the lvds cable from main to LED driver? Because I've done that and nothing happens different. The LEDs never get power. No voltage ever turns on from the LED PSU ever.
                        Also Sony, I watched that video, looks like he is replacing the IC for the main board ? DPS board? I can't Google what that stands for but I found what appeared to be in that video and tested the caps and they were all good
                        • nomoresonys
                          • 12099
                          • U.S.
                          #52
                          I think that N is a fuse, that would explain that board being dead.
                          • nomoresonys
                            • 12099
                            • U.S.
                            #53
                            Ok, looks like it's the sub powerboard.
                            • EazyBone
                              • Jun 2023
                              • 1309
                              • United states
                              #54
                              If it is a fuse, it has no continuity. And could have just been the problem the whole time lol.
                              Also no matter what kind of connections etc I disconnect or any variation of cable disconnection the power board always throws the BL err 3.3 volts no matter what. I have even grounded it per the video and it doesn't have the error then, but it still doesn't work.
                              Diah I have tried all those cables and combinations of those cables and nothing changes. But like I said that N component which may be a fuse has no continuity.
                              • Diah
                                • Feb 2013
                                • 6357
                                are you sure installed the replacement LED in correct order... if you look on the old one the end and abegin of the strips how many lines you have... 4 line mean they will work only in exact order... like Hisense... one group not only at same place one or 2 LED from other strips will light on too
                                so gow us please the strips end of the old one
                                • nomoresonys
                                  • 12099
                                  • U.S.
                                  #56
                                  Think it's got to be a fuse, they are designated F or N, only other N designation I know of is a resistor network component and that sure doesn't look like one of those.
                                  • lotas
                                    • Jan 2016
                                    • 4550
                                    • Russia
                                    #57
                                    "N" - fuse 2A
                                    • nomoresonys
                                      • 12099
                                      • U.S.
                                      #58
                                      LOL, thanks Lotus, I didn't see that label over there.
                                      • EazyBone
                                        • Jun 2023
                                        • 1309
                                        • United states
                                        #59
                                        Man I amaze myself sometimes. That N fuse is good. The solder joints are all messed up and wasn't making good contact. It now reads fine. Blowing my mind here.
                                        Uh diah, I don't have that anymore I tossed them since they were all messed up. None of the strips were different that I know of, they all looked exactly the same. They all also were tested and in-between connects too to see that they would light up. I have no idea how to test them from the ribbon cables driver side.
                                        So the answer is I am unsure if they have it.
                                        Here is only pic I have, would you be able to see the end of it from that pic?
                                        • nomoresonys
                                          • 12099
                                          • U.S.
                                          #60
                                          Check all the solder. Do you have voltage on your blue board now, going in and out?
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • cheeky2
                                            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                            by cheeky2
                                            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                            01-08-2024, 05:56 AM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
                                          • delpiero3
                                            Sony Vaio SVS MBX-261 board failure
                                            by delpiero3
                                            Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                                            Nevertheless, let's say, i don't come as a total beginner.
                                            I have this old laptop, which suit perfectly my needs, with the...
                                            10-29-2024, 06:16 AM
