PHILIPS 42PFL7008k/12 HARDWARE UPGRADE(REQUIRED HARDWARE/EXPERIENCES)!!
  • rakonja
    • Sep 2023
    • 6
    • Croatia
    Hello everyone! I am the owner of a Philips 42PFL7008k/12 TV! It served me well all the years. Sometimes it used to get "stuck", after which I used to disconnect it from the voltage, hold the power button on the device for about 30 seconds, and after turning it on again, it worked like new!Only once it threw something like no software!Now it happened that it won't turn on anymore, the red LED blinks twice!Do you have any suggestions? They are probably not cost effective to repair, but I am sorry to get rid of it, it has served me well and looks like new!The only downside is the slow software! Now I see these upgrade kits! What are the experiences with it......
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4541
    • Italy - Milan
    Re: PHILIPS 42PFL7008k/12 HARDWARE UPGRADE(REQUIRED HARDWARE/EXPERIENCES)!!
    Just to be sure, if u are skilled enough to make smd solderings, try to add solder and refresh the discrete components on the under side of the board under the cpu, especially resistors, lets we see..
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4541
      • Italy - Milan
      🛌🏿 Zzzzzz...
      • rakonja
        • Sep 2023
        • 6
        • Croatia
        Greetings! Unfortunately, I'm not an expert in repairs of this kind! And they ask too much for reballing! And the upgrade kit has appeared again, and has become more expensive! With postage, it would cost around 200 EUR, and I've lost the 3D option! I don't even know what to do now!
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4541
          • Italy - Milan
          why are you here? you aren't even able to solder!? Do you think magic hands comes to your house?
            • 12323
            • U.S.
            200 EUR, that is too much to put into a 42 philips or any philips, might be time to recycle that one and try a different tv, philips are junk imo.
            • rakonja
              • Sep 2023
              • 6
              • Croatia
              No. For me personally, Philips is the best TV, primarily because of the Ambilight technology combined with Android! I've had 4 of them so far, three of them I still use... and in about 10 years, this is the first failure on them! Of course, they go a little crazy here and there, but after a restart, they're like new!
              • rakonja
                • Sep 2023
                • 6
                • Croatia
                Davi....., of course I know how to solder something, but I don't have the necessary knowledge or experience for such a serious procedure! And not even the equipment...! I would like a video where I can see the necessary procedure, please!
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4541
                  • Italy - Milan
                  Yes Philips of some years ago was my favourite TV and often the best...
                  now i don't know..anyway Youtube is the place where to find tons of guides on soldering, search smd soldering, get a 0,5mm tin wire, an 1mm cone shape tip and decent low power soldering iron, put 3seconds the tip on the component, put tin wire on the sol. tip to get it melt then fast slide it to the component, add very small quantity..
                  • rakonja
                    • Sep 2023
                    • 6
                    • Croatia
                    I'll take a look! If it wasn't for the processor, I would have tried something a long time ago! Thank you. Greetings!
                      • 12323
                      • U.S.
                      This is a pretty accurate ranking, with the exception they pushed samsung up way too high, 8-12 are all junk: https://www.slashgear.com/1238354/12...worst-to-best/
                      • Hondaman
                        Hardware firewall to block ad servers?
                        by Hondaman
                        I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
                        The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
                        02-05-2025, 05:04 AM
                      • ahmedtou
                        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                        by ahmedtou
                        help me please
                        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                        I will share all the details with you, including the disc information.
                        Code:
                        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                        Current Profile: BD-R
                        Disc Information:
                        Status: Empty
                        State of Last Session: Empty
                        Erasable: No
                        Free Sectors: 12,219,392
                        Free Space: 25,025,314,816 bytes
                        Free Time: 2715:27:17 (MM:SS:FF)
                        Next
                        08-27-2025, 08:49 AM
                      • Sharpa
                        Repair attempt Philips 55OLED804/12
                        by Sharpa
                        I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                        The symptoms when bought: Philips logo appears then tv turns off
                        Things tried so far:
                        1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                        2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                        11-22-2025, 08:30 AM
                      • alro7779
                        Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                        by alro7779
                        Hello, guys!
                        The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                        09-14-2025, 12:25 AM
                      • G33RT
                        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                        by G33RT
                        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                        It does power up when pressing the power button.
                        I already try the power button while plugin the plug with no result.
                        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                        Could this be an PSU or eMMC issue ?
                        07-19-2025, 03:43 AM
