Philips 50PUS6503 - dead panel? Picture
  • Rubenlily
    • Aug 2023
    • 37
    • Sweden
    Hey,
    I gave up on my last TV and got a new one to try.
    Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
    Is this fixable in any way or should I just give up on this one too?
  • Rubenlily
    • Aug 2023
    • 37
    • Sweden
    Re: Philips 50PUS6503 - dead panel? Picture
    Ok so I've checked all the voltage measures. V12, VGL etc and I haven't found anything weird except VGL that was -10V.
    I also found that this red circled part was extremely hot.
    So I should check this IC right? So I need the datasheet so I can check every pin. Is this correct so far? If so, how do I find it?
    • Rubenlily
      • Aug 2023
      • 37
      • Sweden
      After disconnecting the cable going from mainboard to t-con, the IC is not heating up which mean the panel has the problems... Right? Please stop me if this is unfixable... I'm putting alot of energy into this lol.
      • lotas
        • Jan 2016
        • 4865
        • Russia
        The problem may be in the display bars, take a high-quality photo of these two bars.
        • Rubenlily
          • Aug 2023
          • 37
          • Sweden
          Hey! Thanks. I did, I checked every C0F carefully and didn't see any damage. Thought I might find something burned out. But I did fint something else. I don't know if these might be the problem but they looked a bit messed up compared to the other components.
          I'm talking about R086 and R075. I think they looked a bit damaged, could that be the case? I believe they're labeled "100".
          I'm trying to test them and I get like 1.8-2.0 ohms but I'm not sure if I'm doing it correctly. Power unplugged and just one stick on each side. They look bloated if they're supposed to look like the others lol.
          • lotas
            • Jan 2016
            • 4865
            • Russia
            Yes, they burned out due to TVS diodes, take a photo of these strips in full.
            • lotas
              • Jan 2016
              • 4865
              • Russia
              https://www.badcaps.net/forum/showpo...47&postcount=5
              Read this link that I posted to fix your problem.
              • Rubenlily
                • Aug 2023
                • 37
                • Sweden
                I'll post pictures tomorrow of the full strips. But you're saying if I remove a diode or two it might get restored to normal condition?
                • Rubenlily
                  • Aug 2023
                  • 37
                  • Sweden
                  No way, it's exactly the same resistors!!!!! Wow. I need to find some 10 ohm resistors then to place there. It's not 100 ohms right?
                  • lotas
                    • Jan 2016
                    • 4865
                    • Russia
                    Yes, 101 - 100 Om.
                    • Rubenlily
                      • Aug 2023
                      • 37
                      • Sweden
                      Yes, 101 - 100 Om.
                      Did I fuck up here?
                      I think my soldering iron is bad or that I'm bad. Keep getting the solder stuck on the iron. Tried tinning and cleaning and using the paste but these didn't come off so easily as they probably should have.
                      Anyways. As you can see in the first picture here, I'm missing some silver part. Where the black part is... Did I fuck up bad or is that just dirt/dust?
                      Should I try to clean up before putting on the resistors? I don't want to damage anything and the risk is bigger the more I solder...
                      • Biruslapio
                        • Nov 2013
                        • 552
                        • Brasil
                        Not enough skill to be performing this.
                        You ripped at least two pads, one for the resistor and one for the diode, it's not the end, but it will make it more difficult and more destructive, which is bad to do on a fragile board as this one.
                        The resistor may lead to C010 which is very direct, the diode may be linked to that pad right where the pin should be, need to clean it up with alcohol to see properly.
                        • viewerau
                          • May 2020
                          • 315
                          Try these two threads...sounds like same issue that myself and ruckusman had.
                          https://www.badcaps.net/forum/showthread.php?t=116525
                          https://www.badcaps.net/forum/showthread.php?t=119191
                          Watch out for those solder drops you can see in the picture, clean the diode pads right down with iso, get rid of any excess solder with wick and iso.
                          Good luck, as we know the feeling.
                          Signature:Seemingly hopeless tv fixer
                          • lotas
                            • Jan 2016
                            • 4865
                            • Russia
                            Yes, first remove the remaining flux, rosin with an ear stick moistened with isopropyl alcohol.
                            • Rubenlily
                              • Aug 2023
                              • 37
                              • Sweden
                              I used some alcohol and tried to gently clean it up. Did I fuck up too much to save this?
                              If I broke the diod pad it shouldn't be an issue since I won't be putting anything back there right? But the resistor pad?
                              • Rubenlily
                                • Aug 2023
                                • 37
                                • Sweden
                                I did this and posted some images. Can you see better now?
                                • Rubenlily
                                  • Aug 2023
                                  • 37
                                  • Sweden
                                  Thanks. I don't have any wick but I should get some I've learned. I shouldn't touch the drops that's already there right? Just to be more careful going forward.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4540
                                    • Italy - Milan
                                    The only sensed thing you can do is to set aside this project for a quite long time in the meantime you take confidence with delicate smd soldering techniques, the pads are fucked so a long jumpering is required, the sentence that you are not replacing the diodes is the meter to see how you aren't able to do a good repair.. reselling dirt unstable things is not a good presentation ticket.. u will encounter customers returning back claiming a bad purchase..
                                    • petehall347
                                      • Jan 2015
                                      • 4450
                                      • United Kingdom
                                      next time use hot air
                                      • viewerau
                                        • May 2020
                                        • 315
                                        All these spots of solder won't help either
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • Rauni
                                          Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                                          by Rauni
                                          Hello, this is my first post on this forum, and my first attempted to repair a TV.
                                          My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                                          Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                                          Read also that we should test what happens if we...
                                          10-01-2023, 12:06 AM
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • Schwoin
                                          Philips 243v5lhsb00 Monitor Picture too bright
                                          by Schwoin
                                          Hey everyone,
                                          the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                                          While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                                          you can see them on the top half of the photo.
                                          At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                                          03-21-2023, 12:40 PM
