LG 42LW5500 glitching screen
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    Hello everyone.
    Did anyone seen this kind of fault before?
    As you can see the menu graphics are distorted and the background is this dark greyed striped mess.
    I found that these TVs have a common problem with the mainboard, especially with the CPUs soldering.
    Should I try to reflow it with my hot air station and see it if it helps?
    Thank you
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    Re: LG 42LW5500 glitching screen
    UPDATE
    So I reflowed the CPU and the XD engine on the board, with no luck sadly. The graphics stayed exactly the same.
    However, I thought I reflow the RAM next to the XD engine IC and while the graphics are still faulty, it became different, like no LG logo appearing. Could it be that the RAM became faulty and that's why it producing these weird graphics error?
      • 12181
      • U.S.
      You may have killed the ram, I killed it on a sony board a while back, tried reflowing at about 425 f, tried the board again, no sign of life at all, before the reflow it was partially working.
      • unimatrix93
        • Oct 2021
        • 343
        • Magyarország
        That's the thing. It does "work", it's just the menu and things are all pixelated purple boxes. It's still turns on, it's just now the artifacts are more severe.
        It's similar to when a gpu memory is getting corrupted in computers. That's why I assuming it's the memory.
        Also, the previous owner told me, that it had already bad image quality when he bought it's just became this bad by now.
        • diif
          • Feb 2014
          • 6978
          • England
          I would have advised you to turn your hor air station down past reflow temperatures and get some heat into the processor to see if it mades a difference.
          I've seen faulty gamma ICs on the tcon give that sort of image.
          Is it a decent station and how proficient are you with it ?
          • unimatrix93
            • Oct 2021
            • 343
            • Magyarország
            I already tried a different t-con board and made no difference.
            My hot air station is a 858D. I using it for 2 years now and I know its not the best for big ICs, but I also have a mechanic hot plate station and I usually preheat the board with it to around 130C to help the hot air station.
              • 12181
              • U.S.
              hope you figure it out, I have never seen that kind of defect pattern? on a tv screen, not even on youtube or anywhere on the internet, anyone else see it before?
              • unimatrix93
                • Oct 2021
                • 343
                • Magyarország
                Thank you. I'm probably gonna try and replace the RAM IC. I have a donor board which have the same kind of RAM just a 2GB one. This board has 1G chips.
                Do you think I can replace with a bigger capacity one or should I get a same capacity one?
                  • 12181
                  • U.S.
                  I don't know but that's a very good question.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4327
                    • Italy - Milan
                    it is not the right way to produce a photo for help asking reason.. need a straight one with a decent source plugged in...
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • spice_disc
                      Vizio TV M50-C1 reboot cycle and static on screen
                      by spice_disc
                      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                      09-08-2024, 02:37 PM
