Jvc hr-d470eg
  • hugocarmo
    • Feb 2021
    • 39
    • Portugal
    Jvc hr-d470eg
    Hi everyone.
    I bought this vcr, I don´t know if you are like me, but I´ve never heard of a vcr with a side loading mechanism...
    It was working, but the only problem was that as I loaded the tape, it started playing and a second after stopped, FF an RW equal.
    I have seen some youtube videos that showed that maybe was the reel sensor, the only difference was that mine, changed the counter from 0000 to 0001 or 0002, so I was not convinced that it was the problem... Dispite that, I connected my bluetooth receiver through rca cables to input, and I only had left channel in stereo, only in mono I had both channels, so I decided to disassembly it, download the service manual, and order all electrolytic capacitors for all boards, including PSU, in the hope to have a 80´s fantastic engeneering device for mora 40 years or so...
    I took pictures of all boards and connections, but after all caps replaced, I swapped power transistor plug "CN6" to "CN5", it has the same pin count so I stupidlly wrong connected it, when I plugged it to mains, the "Fuse2" burned all of the sunned, then I connected the mains to my serial bulb short protector and replaced the fuse, but everytime i turn the mains on, the fuse blowed, until I figure out that the plugs were connected wrong.
    My question is... After connecting all right, I measure voltages in PSU and none look like in the service manual.
    I replaced again all electrolytics in th PSU, but still the same.
    I´ll attach all the service manual I have and pics and video from my device.
    https://drive.google.com/file/d/1oeP...usp=drive_link
    https://drive.google.com/file/d/1Zgj...usp=drive_link
    https://drive.google.com/file/d/1437...usp=drive_link
    Thank You all,
    Hugo.
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Jvc hr-d470eg
    most problems i found with vcr.s are bad tapes shredding and clogging the heads .
    • hugocarmo
      • Feb 2021
      • 39
      • Portugal
      Re: Jvc hr-d470eg
      You could be right, but in my case, It doesn´t power up...
        • 12141
        • U.S.
        Re: Jvc hr-d470eg
        Can you highlight the two "power transistor plugs' that you mixed up, with good focused pictures of the whole area, for original problem, what exactly did it do? Looks like you put tape in, push play and 2 seconds later it ejects the tape on it's own, is that correct?
        • R_J
          • 9535
          Re: Jvc hr-d470eg
          What do you mean voltages are not like the service manual? which voltages? what voltage are they?
          Post the voltages you get on power supply board CN6
            • 12141
            • U.S.
            Re: Jvc hr-d470eg
            That is a really good video of replacing that counter sensor, I think this is the one you refer to, looks like yours is working, the video does show the innards of this model very well, might be able to get some clues from it: https://www.youtube.com/watch?v=FFHd2tOaNdQ
            • hugocarmo
              • Feb 2021
              • 39
              • Portugal
              Re: Jvc hr-d470eg
              I nomoresonys.
              You´re right, I´ve seen the video before got courage to disassembly my vcr and replace all electrolytic caps, hoping my problem was only bad readings from eeprom and the sensor was good, but after replacing all the caps, as I said, I mixed up the plugs on the boards.
              After measuring on cold, all the PSU components, I figured out that when I mixed up "CN6" to "CN5" the "R1" 10ohm fuse resistor burned out with "Fuse2" Thank God it did, I replaced it with a 2W 10ohm just to test and the VCR came to life again, all two audio channels work, beautifull sound, but the reel sensor doesn´t work, it starts to play and stops just like the youtube video. I searched on google, I can find the sensor, but only in foreign sites, that dont ship to Portugal.
              If you or someone can ship the sensor to me I´ll pay for it.
              The sensor it this...
              https://www.donberg.ie/descript/g/gp_3a21.htm
              Thank You all!!
              Hugo.
              • R_J
                • 9535
                Re: Jvc hr-d470eg
                Do you have the SWD 5V-1 on pin2 of CN5 of the power supply? this supplies voltage to the sensor
                • hugocarmo
                  • Feb 2021
                  • 39
                  • Portugal
                  Re: Jvc hr-d470eg
                  Hi R_J.
                  I figured out the problem, as I said, the fuse resistor "R1", burned out as When "Fuse 2" burned too.
                  After replaced the resistor, the VCR came to life again...
                  The problem now is the reel sensor...
                  Thank You, I really appreciate your answer!
                  Hugo.
                  • R_J
                    • 9535
                    Re: Jvc hr-d470eg
                    Originally posted by hugocarmo
                    Hi R_J.
                    Hugo.
                    So the reel sensor is getting 5v but just not outputting a REEL FG pulse? on1317 seems to be the same sensor. If you can't find one you may be able to replace the defective component in the housing, I have done this in the past. If the led is bad it's easy if its the 3 lead detector it may be harder to find
                    • hugocarmo
                      • Feb 2021
                      • 39
                      • Portugal
                      Re: Jvc hr-d470eg
                      You´re right.
                      But my first problem was that when I swapped CN6 to CN5, Fuse2 burned out, and later on I figured that R1 (10ohm) fuse resistor burned too, Before I started to replace all the electrolytic caps, the reel sensor problem was there, but I tought that was only a cap problem, but It wasn´t... Unfortunately...
                      So I need a reel sensor like the one I put on the link...
                      I think it´s not easy to find in EU, but I´ll pay the shippment costs if it´s shipped from US...
                      Thank You.
                      Hugo.
                      • R_J
                        • 9535
                        Re: Jvc hr-d470eg
                        The part number is GP3A21, 0N1317 may be the same
                        • hugocarmo
                          • Feb 2021
                          • 39
                          • Portugal
                          Re: Jvc hr-d470eg
                          I didn´t find any with 0N1317 but with PU60271 I found.
                          But still haven´t found any store who ships to Portugal.
                          donberg ships, but only 50€+...
                          If someone can buy it from another site and ship for me I´ll pay for the sensor ans shippment costs...
                          The other site I found is in Australia!
                          https://www.wagneronline.com.au/jvc-...-5352/2043/pd/
                          Once again,
                          Thank You R_J!
                            • 12141
                            • U.S.
                            Re: Jvc hr-d470eg
                            So then it was the reel sensor after all, did you verify like he did in the video?
                              • 12141
                              • U.S.
                              Re: Jvc hr-d470eg
                              Is that it? I don't know anything about the seller, it looks legitimate but I have not dealt with them myself: https://www.electronic-spare-parts.c...s/gp_3a21.html
                              • hugocarmo
                                • Feb 2021
                                • 39
                                • Portugal
                                Re: Jvc hr-d470eg
                                Hi nomoresonys.
                                That store is the same as donberg.ie, the problem is that they only accept a minimum order value of 50€.
                                I´ll keep on searching
                                Thank You,
                                Hugo!
                                • hugocarmo
                                  • Feb 2021
                                  • 39
                                  • Portugal
                                  Re: Jvc hr-d470eg
                                  Could this one work like the original one?
                                  It has 5 pins too...
                                  https://cdn.badcaps-static.com/pdfs/...7602c937a7.pdf
                                  Thank You.
                                    • 12141
                                    • U.S.
                                    Re: Jvc hr-d470eg
                                    I see, didn't know that was their policy, hate when they do that, they usually always charge shipping, I don't get it, guess they just can't be bothered with anything less than 50. I won't deal with those types if I can avoid it.
                                      • 12141
                                      • U.S.
                                      Re: Jvc hr-d470eg
                                      One there, didn't read the particular details tho: https://www.ued.net/ued/viewItemActi...Code=JVCGP3A21
                                        • 12141
                                        • U.S.
                                        Re: Jvc hr-d470eg
                                        Some info there, maybe someone can make sense of it: https://www.datasheetarchive.com/?q=GP3A21
                                        • Loretto
                                          Samsung SMPS BN44-00339A
                                          by Loretto
                                          this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
                                          I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
                                          I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
                                          I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
                                          03-29-2025, 08:30 AM
                                        • Loretto
                                          by Loretto
                                          03-28-2025, 10:28 AM
                                        • Dannyx
                                          Help with LNK304PN power supply (Whirlpool auto washer)
                                          by Dannyx
                                          Good day folks. A pretty simple job turned into a great confusion today. My boss sent me over to a friend of his to have a look at his washing machine which stopped working entirely. He opened it up himself and presented me with this lovely board before I got there. I took it back to the shop and instead of immediately hopping online and trying to find info on this board, I opted for a more hands-on approach and troubleshooted on my own.
                                          The layout seemed pretty simple overall and it wasn't hard for me to spot the issue: the power supply in the lower-right corner had popped. I noticed...
                                          08-11-2021, 10:16 AM
                                        • Grouickman
                                          Hofmann geodyna 6300 Wheel balancer
                                          by Grouickman
                                          Hi there,
                                          First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                                          Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                                          I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                                          I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                                          03-31-2025, 05:29 AM
                                        • Goldwing1973
                                          Sonos Play 1 pulsing power supply
                                          by Goldwing1973
                                          I'm rather new to repairing electronics, i do know the basics of most components but never actually repaired a PCB, but i want to change that.
                                          So, i bought a faulty Sonos Play 1 speaker with the intention of finding the fault, and replace the damaged part.
                                          Well, i did find the fault, i replaced parts that i thought caused the problem, but no-go.
                                          The problem is a pulsing power supply, when i connect the mains to the board and hook up my thermal cam i see R306,307 and 308 getting warm, but i assume that's normal.
                                          But, whats is not normal is the pulsing of resistor...
                                          07-04-2025, 12:59 PM
