samsung un58tu7000u bootloop and no display
  • aabb
    • Aug 2023
    • 8
    • united arab emirates
    HI everyone , I have this samsung un58tu7000u tv with boot loop . i been reading all these threads regarding boot loop and i managed to get the screen show now vertical bars but no solid image.
    The tv came to me with no image and boot loop
    these are the things i did
    1. I remove PSB input to MB ,the backlights are working fine ,no boot loop
    2.Connected PSB input to MB ,boot looping
    3.Disconnected the flexi cable from MB to panel input , no boot loop
    4.Connected the flexi cable and removed the U shape flexi cable on panel pcb to isolate right side of the panel ,still boot loop
    5.Tried the masking trick and after various combination ,masking pin 28 on the flexi cable from the MB output side, no boot loop and the tv show line on display
    i have done voltage check on the panel side and i am getting 24v dc on both side of the panel.
    Anyone who can guide me beyond this will be really appreciated.
    The tv MB is BN41-02751A-000
    PANEL IS CC580PVD60
    COF IS NT30226H-C7610A
    i am determined to know what is going on with this tv
    any help with schematic of the MB or COF will be really a good step
  • aabb
    • Aug 2023
    • 8
    Re: samsung un58tu7000u bootloop and no display
    just an update to previous post i forget to mention the voltages
    here are the voltages on both side of the panel both sides
    1. ck1-ck8 = -6v dc
    2.clr,stv,vss,lc1,lc2 =-6vdc
    3. vgh = +24vdc
    i dnt know what extacly these voltages are meant to be and the values.
    any expert can help
      • 12206
      • U.S.
      Put up some good clear pictures of the panel driver boards and their connections, one easy thing to do is clean the ribbon cable ends with isopropyl alcohol, some use pencil erasers, not too vigorous they can be delicate.
        • 12206
        • U.S.
        Another easy test, test the little mlc caps on the panel driver boards, probe on each end, check for shorts or very low ohms.
        • aabb
          • Aug 2023
          • 8
          Hi i am attaching some pics and sorry if i ask some silly questions as i am not a electronics nerd .. i m just learning from this forum .
            • 12206
            • U.S.
            I see, so what kind of nerd are you? lol, did you test those caps per post #4?
            • aabb
              • Aug 2023
              • 8
              well i am an aircraft engineer type of Nerd.. anyhow that is not important ... yes i check all the capacitor on the panel with multimeter .one side is grounded and other side show not grounded so that are all ok.. To me the voltages look not ok... all negative except VGH.
              the screen no display and just lines seems like something wrong with voltages. I downloaded the panel datasheet from the this forum CC580PV6D and as you can see the pin which i masked in pin no.28 ,which as per datasheet is VGH2.
              if i remove the mask from pin 28 then tv will start boot loop
              so the problem are many bt first i want to get the screen back without the lines which i guess some electronics samsung nerd can solve
              • EazyBone
                • Jun 2023
                • 1348
                • United states
                Is there a post that shows pictures of these mlc caps? And where to put leads? I don't have this tv but curious trying to learn thanks
                  • 12206
                  • U.S.
                  @ EasyBone. Probably is somewhere, maybe try the search, there's a youtube video there, there's plenty more on youtube but finding a good one might take a little searching: https://www.youtube.com/watch?v=EfTbAIDj_YY
                    • 12206
                    • U.S.
                    Sometimes you can not get a good picture just masking one line, try masking about 15 pins on the bad side, sometimes it takes trial and error and sometimes it's just not fixable, in some cases it can be a bad diode array or bad resistor/s or other component on those boards.
                    • aabb
                      • Aug 2023
                      • 8
                      well i have done all those trail and error hours and i reach up to this point .. the videos on youtube are not specific to this model and few are there but language barrier..
                      the thing is i want to know these negative voltages i am getting on all test point excpt the VGH is very odd and i want to know why.
                      can someone tell me why all are negative readings
                      • aabb
                        • Aug 2023
                        • 8
                        update......I scraped the tv.
                          • 12206
                          • U.S.
                          Well done, that model is a PIECE OF SHIT.
                          • Storyteller12
                            • Jun 2020
                            • 624
                            I’m learning any Samsung tv that has a “U” is shit.
                            KU, MU, NU, TU and even the new CU is already dead at my local Walmart
                            • lotas
                              • Jan 2016
                              • 4660
                              • Russia
                              "u" - uhd (3840х2160).
                              • Storyteller12
                                • Jun 2020
                                • 624
                                I'm aware but those models have problems. Samsung makes higher end TV that are UHD and don't have as many problems as these.
                                The KS series and higher end QN series are UHD TVs are a lot better. They have faults as well but at least you get 4+ years before any problems for the most part.
                                • aabb
                                  • Aug 2023
                                  • 8
                                  just to let you guys know the VGH on left side of the panel was short.
                                  how i know...i cut all the vgh,sk1-sk8 and other test point on the panel board
                                  then i tried connect VGH first by solder...and that bloody thing was short tv start bootloop..that circut is bloody small to track where VGH goes . so i call it a day and junk the tv in store to ROT..
                                  • Takeatry
                                    Yet another Samsung QLED Boot Loop
                                    by Takeatry
                                    Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                    10-04-2024, 02:57 PM
                                  • torchzack
                                    Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                    by torchzack
                                    Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                    I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                    Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                    08-28-2023, 07:42 AM
                                  • NolesFan
                                    Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                    by NolesFan
                                    Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                    10-24-2024, 06:36 PM
                                  • eigma
                                    Samsung UN40H5003 boot loop every ~8 seconds
                                    by eigma
                                    Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                    Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                    SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                    Main board: BN94-07592P / BN97-08922R...
                                    11-20-2024, 10:31 PM
                                  • blaster_
                                    Samsung UE49MU6105K - boot loop, horizontal lines
                                    by blaster_
                                    Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                    Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                    06-22-2022, 05:19 PM
