Strange problem with Sony XBR-85X850G 85" LED tv
  • mitsu2k
    • Aug 2013
    • 219
    I am working on a Sony XBR-85X850G tv and I am puzzled as to what could be wrong with it. My friend took it to a repair shop where the shop stated they had replaced the Main Board and T-CON board but the problem remained unchanged. The repair shop said they felt that the panel was bad. I am not sure the panel is bad. I could be wrong but most bad panels I have seen the vertical lines remain fixed. However the vertical lines here move around and take on various colors and patterns, width, etc. Also, the display aspect ratio almost seems that it has shrunk to 4:3 as I can see black borders on the sides. I have factory reset the tv and when I try to make selections during initial setup, for the first few seconds I can see the items on the screen but I cannot select them. Meaning I do hear the "ding" sound as if it is moving from selection to selection but the highlight/cursor does not move from selection to selection. It could be that I am selecting things when I hit enter but the display is not registering the chosen selections. Very strange.
    Any help, suggestions or advice is most appreciated. Please see photos.
    p.s. I just wanted to mention that I also did check and clean all the ribbon cables.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4537
    • Italy - Milan
    Re: Strange problem with Sony 85" LED tv
    100% panel fault, but which part? Distribution pcb or cof?? Seems a problem on the clock lines but all togheter means maybe an overload/overheating of a shorted cof, since gate signals are not involved with capacitors then leave them alone, the only your hope are protection diodes on dist. pcb..
    • mitsu2k
      • Aug 2013
      • 219
      Thank you Davi.p, can you explain to me what the dist. pcb is and where it is located? Also what is "cof"?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4537
        • Italy - Milan
        dist. boards= the large short boards glued onto the panel, cof= the driver chips glued to the screen, not replaceable
        • mitsu2k
          • Aug 2013
          • 219
          Thank you, you mentioned protection diodes. Can you please enlighten me on what these look like? I see 3 components on each side on the driver/dist board (total 6) right underneath the ribbon cable. They are marked D004, D005, etc. each chip has 8 legs. Can these be the protection diodes?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4537
            • Italy - Milan
            Yes are them, must remove them one by one with hot air and see, or if you are lucky you can locate the faulty one by measuring each clock line with oscilloscope or frequency meter and see the perturbated one
            • mitsu2k
              • Aug 2013
              • 219
              Are these the protection diodes? I cannot find these part numbers or datasheet online.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4537
                • Italy - Milan
                Re: Strange problem with Sony XBR-85X850G 85" LED tv
                first you must ensure them are the problem
                • mitsu2k
                  • Aug 2013
                  • 219
                  Yes I understand, that's why I need a datasheet so that I can know which pins are what so I can test with multimeter.
                  By the way, thank you Davi.p!! I appreciate all your help.
                  • mitsu2k
                    • Aug 2013
                    • 219
                    Is there any chance this can be a bad T-con board? I am just puzzled because both sides of the panel developed the lines at the same time.
                    • R_J
                      • 9625
                      Amazing Microelectronic Corp. AZ1043-08F.R7G
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4537
                        • Italy - Milan
                        Nooooooo! You can't affordably test them i gues, the fault is dynamically showed as i have said the shortest easiest way is to desolder them one by one until fault disappears. to find wich side board is you can didconnect one flat cable at a time or if it's a Samsung panel you can use the Samsung trick before... post a bright picture of the tcon
                        • mitsu2k
                          • Aug 2013
                          • 219
                          Nooooooo! You can't affordably test them i gues, the fault is dynamically showed as i have said the shortest easiest way is to desolder them one by one until fault disappears. to find wich side board is you can didsonnect one flat cable at a time or if it's a Samsung panel you can use the Samsung trick before... post a bright picture of the tcon
                          Ok, when I disconnect one side of ribbon cable going from T-con to the panel (dist.) board, I get no display, no lines. Just backlight.
                          When I unplug other side of ribbon cable, I get lines only on same side.
                          The panel boards are total 4 boards. Each pair of 2 boards are paired together with ribbon cable. When I disconnect one side, I get some other type wide faded line on that side. When I unplug the other side, I get the exact opposite.
                          This is what makes me think it's maybe something else like the T-CON. I am puzzled.
                          Also I want to note that when I first turn on the tv from cold start, the picture looks good for the first 2 seconds but then the lines start to appear. It's like as soon as something heats up, the lines come.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4537
                            • Italy - Milan
                            Ok so you don't trust me, glad to hear, so i suppose you can continue by yourself...
                            • mitsu2k
                              • Aug 2013
                              • 219
                              I never said that. I appreciate your help. I am just asking a question.
                              Ok maybe you can explain to me what symptoms of a bad T-con look like?
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4537
                                • Italy - Milan
                                Bad tcon has an uniformed mulfunction on screen, the whole screen is affected in the same way..
                                • mitsu2k
                                  • Aug 2013
                                  • 219
                                  Sorry Davi.p, I didn't realize you had asked for a photo of the T-con. Here it is.
                                  Also, Here are some photos when I blocked various pins of the ribbon cables with kapton tape
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4537
                                    • Italy - Milan
                                    that white horizontal line doesn't like to me, screen is Auo not Samsung so no trick
                                    • mitsu2k
                                      • Aug 2013
                                      • 219
                                      So you suggest removing the protection diodes one by one until the problem disappears if it disappears? I suppose I can try and do that. I have nothing to lose at this point.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4537
                                        • Italy - Milan
                                        of course..
                                        • Chrissygizmo
                                          Sony KD-55XG9505 lines on screen problem
                                          by Chrissygizmo
                                          Hello again everyone,
                                          This is my latest mission, to try getting this Sony tv back to normal working order…
                                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                          02-19-2025, 11:31 AM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • crackedprint
                                          Sony HCD-HX80R Amplifier Volume Control Problem
                                          by crackedprint
                                          I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                          I have tried a Cold Reset as per the service manual.
                                          I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                          I have looked all the way through the service manual and tried many online...
                                          01-21-2025, 12:18 PM
                                        • retrorepair
                                          SONY KDL-40P3600 Picture Problem
                                          by retrorepair
                                          Hello gurus, hope you can assist me...
                                          I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                                          I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                                          Thanks in advance.
                                          10-11-2024, 05:12 PM
                                        • guruji
                                          Sony mbx-266 problem
                                          by guruji
                                          Hello
                                          I this Sony mbx-266 it powers
                                          on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ??
                                          07-25-2025, 08:10 AM
