Sony XBR-65X850E No Power
  • Storyteller12
    • Jun 2020
    • 625
    Tv won't turn on. Not sure if there is a standby light on this TV but I'm not seeing any.
    Checked the usual diodes that go bad and all test good. When plugged in 2 show 100v and the other 2 50v when plugged in.
    Below is reading for CN6401
    1) 0v - blinking
    2) 0v - pwm1 dimmer
    3) 0v - DC dimmer
    4) 0v - 0wm2 dimmer
    5) 3.5v - Standby
    6) 0v - pwm3 dimmer
    7) 0v - BL On
    8) 2.6v BL Error
    9) 3.5v PWR On
    10-12,19-24) 0v - ground
    13-18) 12v all pins - 12v reg
    25) 0v - tcon vcc 12v
    27-28) .5v - tcon vcc 12v
    26) 0v - tcon on
    Also I tested backlights with my tester and all pins show 119v. So assuming they're good but not positive since I get 2.6v on bl err pin.
    I know a lot of these Sony have bad emmc also but not sure how to confirm if that's my problem.
  • lotas
    • Jan 2016
    • 4753
    • Russia
    Re: Sony XBR-65X850E No Power
    Check all the fuses, there are a lot of them on the board with the designation "Fxxx", there is a duty LED, turn off the Wi-Fi module, measure the resistance on the HDMI signal lines relative to ground...
    • Storyteller12
      • Jun 2020
      • 625
      I measured all fuses and they test good. I couldn't find the fuse labeled F2800 to measure it. They're so small and really hard to see.
      I removed the Wi-Fi card and measured resistance on HDMI and got 5-6 ohm on all 4.
      I posted a close up of the fuse I can't find. Maybe someone else will see it and point it out.
      • lotas
        • Jan 2016
        • 4753
        • Russia
        But 5-6 Om is a short circuit, this should not be, if this is the case, then only a processor replacement or a motherboard replacement.
        • Storyteller12
          • Jun 2020
          • 625
          Ok, I was leaning towards a bad mainboard but didn’t know how to confirm.
          I appreciate your help. Is there anywhere to buy processor?
          • lotas
            • Jan 2016
            • 4753
            • Russia
            Here it is better to look for the motherboard, since Sony is linking the processor and eMMC firmware by ID ...
            • Storyteller12
              • Jun 2020
              • 625
              Appreciate the help. I can’t seem to find a main board so I’m sending out for repair to a reputable guy in North Carolina. I’ll post back after I get the board back
                • 12276
                • U.S.
                Prolly bad e-nand, notorious problem for sonys.
                • Storyteller12
                  • Jun 2020
                  • 625
                  Just got the board back and everything works. It was the emmc that failed as usual.
                    • 12276
                    • U.S.
                    eMMC Flash combines NAND memory with a built-in controller that handles most of the things you have to take care of when dealing with NAND flash. eMMC is also called managed NAND.
                    • Daren87
                      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                      by Daren87
                      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                      08-13-2023, 03:25 PM
                    • iglitare
                      by iglitare
                      09-04-2025, 07:13 AM
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • thelankanguy
                      Sony KD-55X9000F TCON Issue
                      by thelankanguy
                      The TV shows a black screen with no image.
                      TCON ribbon connectors were disconnected individually for image and there was no half image even.
                      Later both ribbons were disconnected and TCON voltages were tested.
                      12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                      There is also a short to ground in this circled inductor.
                      Is this a TCON issue or something else ?...
                      12-13-2024, 12:27 AM
                    • bbrain
                      Sony KD-55AG9 TCON?
                      by bbrain
                      I have this problem with my Sony 55' AG9.
                      It flashes 4x.
                      I have found the service manual, and seems it is the TCON.
                      Before I buy a TCON can someone check the vid?
                      Thanks in advance!...
                      09-19-2024, 10:50 AM
