Panasonic Viera mod: TC-L39EM5X
  • Quantum IC
    • Sep 2021
    • 20
    Hello guys,
    I have this TV that has a large or stretched image as you can see in the following video.
    Is the first time I see this problem.
    At first I thought there was a configuration problem in the user menu, but it's not.
    I need your sage advice to fix this problem.
    I have my doubts about the main board firmware or bad panel.
    But I want to know what repair tips you guys give me.
    Best regards.
    • 12187
    • U.S.
    Re: Panasonic Viera mod: TC-L39EM5X
    Try a factory reset if you have not.
      • 12187
      • U.S.
      Maybe try going into your regular menu in display settings and see if there's a reset to defaults or similar there.
      • Quantum IC
        • Sep 2021
        • 20
        I already reset all the settings in the user menu with no results. The image remains the same.
        • Quantum IC
          • Sep 2021
          • 20
          I try to enter service mode with this sequence:
          While pressing the [VOLUME (-)] button on the main unit, press the [INFO] button on the remote control three times within 2 seconds.
          But I don't know how to navigate in this menu.
          The folowing optios are displayed:
          (See attached picture )
          If you know how to navigate this menu and where I can perform a factory reset, I would appreciate your help.
            • 12187
            • U.S.
            That may be the wrong menu, try menu +1147 or menu +2383, see if something like factory settings shows up you might want to select shipping mode then press ok on remote, always record your original settings in case you need to go back to them and remember it's pretty easy to brick your tv if you set things wrong in the service menu.
              • 12187
              • U.S.
              Do you know the history of this tv, I have seen things like this before when there was a mismatched mainboard put in.
              • CapLeaker
                Leaking Member
                • 8150
                As nomoresonys said and also my first thought was, the panel and the main board doesn’t match. Or someone frigged around with the factory settings.
                • Quantum IC
                  • Sep 2021
                  • 20
                  Hello nomoresonys,
                  my client bought this TV like this.
                  This TV had already been repaired previously since the two flexes that go from the T-Con to the panel are different from each other.
                  Even one of its speakers is not the original. It's different too.
                  The button sequence (menu +1147 or menu +2383) doesn't work.
                    • 12187
                    • U.S.
                    Ok, can you tell us your panel number? should be on the back chassis somewhere.
                      • 12187
                      • U.S.
                      Can you post a good clear picture of both white stickers on the mainboard if there's 2, or type out all the alpha-numeric numbers and letters.
                        • 12187
                        • U.S.
                        This looks like the right board, see if yours matches up, probably look for 431C6470L11, on the white sticker: https://www.shopjimmy.com/panasonic-...rd-tc-l39em60/
                        • mostachio
                          Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                          by mostachio
                          Hi Badcaps,
                          I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                          TV Details:
                          Model # - TH-65DX700Z
                          Symptoms:
                          The television turns on and displays a picture then makes a clicking sound and turns off.
                          I haven't opened it up yet but...
                          09-04-2024, 02:32 AM
                        • Ama Chur
                          Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
                          by Ama Chur
                          After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
                          02-21-2025, 08:12 PM
                        • badcappo
                          Dead Panasonic Viera TX-P65STW50 Plasma TV
                          by badcappo
                          Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                          Diode type G972s6 - D101 with a short
                          Mosfet 06N90E - Q301 shorted
                          Fuse T5AH 250V - F103 blown
                          Diode D301 shorted
                          Relay DG1U-17VDC II - RL001 blown
                          I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check πŸ˜€...
                          11-24-2024, 11:27 AM
                        • J8rda7
                          Panasonic Viera TX-L50E6E - no image
                          by J8rda7
                          the TV has a black screen. Sound OK, backlight OK.
                          When I measure T-CON voltages, there is VGL+VGH=0V. After unplug the right side of the screen from the T-con, voltages are OK and half screen works normally.
                          I tried to search for any kind of short on the right side, but I had no luck. I have a beginner experience in measuring and repairs of the LCD panels..
                          Thanks to anyone who can guide me in solving the problem.. and be patient with my english πŸ™‚πŸ˜
                          05-13-2024, 11:04 PM
                        • Andre Gilbert
                          by Andre Gilbert
                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                          11-20-2024, 08:52 PM
