Hi all, I have a EBR73561201 Ysus board on a LG 60PV400 that clicks off after 2 seconds when powered up. I am 99% sure the problem is the YSUS board because when I power up the TV with it disconnected the tv stays on and I have tested the buffers and when the buffers are disconnected and the YSUS is powered the TV shuts down. I did replace a couple of FGPF4633 transistors that were shorted and tested all gate resistors but it still will shut down once I hook up the ribbon cable from the control board. I retested the transistors I replaced and tested the gate resistors and they seem fine. Anyone know where else to look on the YSUS board or what other components are replaced when purchasing the repair kits for these boards. Thanks
YSUS EBR73561201 clicking off on a LG 60PV400
Tags: None
Re: YSUS EBR73561201 clicking off on a LG 60PV400
I'm working on the exact same board right now. I fixed it before and it worked for 6 months. Check all the RF2001 diodes . Some are attached to heat sinks, a couple aren't. When I fixed this before, it was some RF2001's, Some FGPF4633's, some gate drive ICs (FAN73711) and there's some npn/pnp transistor arrays which were also bad. Can't remember the original PN, but I replaced them with CPH5506-TL-E. Both boards had issues. Right now I no longer am popping FETs, but still no picture or even pre charge flash. Both boards hum.Last edited by lookimback; 10-31-2018, 09:04 PM.------------signature starts here------------
I found 3 more FGPF4633 transistors on the silver heatsink in the middle of the board that were shorted, I didn't see these at first because they were completely covered with the silicone goop. I replaced them and now the tv is working. I have tested it for over 30 minutes.....So far so good. I tested all the gate resistors and surprisingly they were good.Comment
Good job! I found two bad resistors, and two more bad FGPF4633s on the Y smd Z boards, but I still have a short somewhere on the Y. I use a lightbulb in series with VS ro limit current so I don't blow the replaced FETs. It's odd because it lights dim, then goes out, and that's the expected behavior, but then about a second later the bulb comes on bright and stays on.------------signature starts here------------
Have you checked all the 270 gate resistors on the 4633 transistors ? they should read about 13.5 ohms when in parallel. Surprisingly mine were fine but they usually blow when the resistor shorts.
Good job! I found two bad resistors, and two more bad FGPF4633s on the Y smd Z boards, but I still have a short somewhere on the Y. I use a lightbulb in series with VS ro limit current so I don't blow the replaced FETs. It's odd because it lights dim, then goes out, and that's the expected behavior, but then about a second later the bulb comes on bright and stays on.Comment
Checked them all. Last time some were bad, but not this time. I notice VSC is only 12v. Possibly it would be higher if I wasn't using the lightbulb limiter, but definitely still quite low.------------signature starts here------------
by PlasMattI have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
by SiskoHi all!!
Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...4 Photos-
Channel: Troubleshooting Audio Equipment
by B0r1sPSU - BN44-00878A
Symptoms:
The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
A weak clicking sound was coming from the transformer.
Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
Progress:
After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I... -
by leggLG42PC3D -UD originally with green lamp but no display or audio.
Owner says was working, then went 'pop'.
All 5V caps bulging. replaced.
All PSU output voltages within spec but -Vy is low on YSUS.
One of three parallel fets between SUS_OUT and SUS_DN is zenering,
eventually shorts DG. Replaced all 3 - -Vy now OK.
Y scan buffer test point does not follow YSUS output below -50V
Note: This unit seems to expect YSUS output to park at -Vy in between
drive signal pattern periods. A replacement drive signal board confirms this....11-18-2021, 11:49 AM -
by slimmy182Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
Looking on google I found this:... - Loading...
- No more items.
