Samsung hl67a750 dlp tv, (bad cap)??
  • CHRIS341
    • Sep 2010
    I have a samsung hl67a750 led dlp tv, i have had it over a year now
    and of course it is out of warranty. Picture went out, i looked in back,
    main power supply and a sub power supply. Checked the main- ok
    the sub power supply cap, was enlarged a little, on sub power supply
    that sends power to the led lights marked on board is says 16v,
    with meter, turn on, voltage to led driver board starts out at 15.78
    and of course tv wants to restart so voltage drops and unit restarts.
    Taking a chance i ordered a cap from digikey,(same value)
    and have the same results.
    At one point i unpluged the connections that go to the led's
    r,g,b, turned unit on and one by one pluged them back in to place
    wow a picture,,,or so i thought, sounds like the transformer on sub power board is buzzing.
    I have been looking all over internet for some info about this model and can't
    find much,i did how ever find a video on you tube about sub board replacment
    the poster from saudi arabia emailed me a repair manual but no real voltage numbers that i can work with.I don't know what the main board is designed to send to the sub board. Has anyone worked with this model?
    C D'Orio
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Samsung hl67a750 dlp tv, (bad cap)??
    Go to this site. http://elektrotanya.com
    Put in the model number. You will find a service manual for that DLP set on the site. I seen it and downloaded it. I am not familiar with DLP's so thats all I can help you with. The download was 12Mb. I normally would attach them to the post but the forum limits PDF's to 9.6Mb's and lower.
    • CHRIS341
      • Sep 2010
      Thanks dgtech!
      C D'Orio
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • Nicktronic
        Samsung Power Supply Board BN44-00874F
        by Nicktronic
        Hey everyone,
        This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
        Anybody...
        03-17-2025, 06:20 AM
        After all of...
        07-13-2024, 08:14 PM
      • repair-it
        Need advice testing a samsung power supply board with scope
        by repair-it
        I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
        07-12-2025, 11:00 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
