Sony XBR-65X750D Horizontal lines bottom of screen
  • howardc64
    • Jun 2017
    • 653
    Re: Sony XBR-65X750D Horizontal lines bottom of screen
    UPDATE : Blocking off VGH VHG_ODD VGH_EVEN AND CLK4 fixed the picture completely I figure line 13 was CLK4 (line 16 to 13 is 4)
    I could remove the resistor/fuses on the buffer board for these (VGH need to be cut) but probably no difference from masking off the t-con output?
    • nomoresonys
      • 12312
      • U.S.
      #62
      Great work Howardc64, that took lots patience and knowledge.
      • nomoresonys
        • 12312
        • U.S.
        #63
        Not crazy about the xbr's but now if I run across one with similar issue, I know what to do.
        • howardc64
          • Jun 2017
          • 653
          One thing positive about these XBRs is they are incredible thin (females seems to fans haha) and surely edge lit which provides a very even backlight. The cheap HiSense and TCLs I've worked on try to go thin with stuck on reflector paper with standard backlight bars. Almost never go back on with even backlight... probably wasn't that even coming out of the factory haha.
          • nomoresonys
            • 12312
            • U.S.
            #65
            I hear that, the 65x900c I have, most of it is 3/16 of an inch thick, on the bottom part with all the boards add a little thickness but it's still like less than 2 inches thick in that area, very slim indeed, too bad I messed it up.
            • ggil44
              • Aug 2011
              • 105
              #66
              Thanks for the updates Howard. I have been a little "burnt out" (pun intended) with the Sony TV but I will keep your fix on file when I try to "erase" those lines again. Glad to hear that you finally found the source of the problem. Congratulations!
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • Raulnn
                Sony KDL-50W685A horizontal black lines Pattern
                by Raulnn
                good morning! I have a problem with this Sony. The image has a pattern of black horizontal lines, I attach a photo of the lines. The power supply is external and emits a sound. I don't think it's because of that. Let's see if someone can help me.
                12-10-2023, 06:50 AM
              • kdaniel
                Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
                by kdaniel
                As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
                There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
                After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
                Left...
                11-16-2022, 09:23 AM
              • dvu0627
                Sony XBR65X900H TV with Horizontal Lines right half of screen
                by dvu0627
                I have a Sony Smart TV XBR65X900H that started to have horizontal lines on the right side of the screen (see attached picture). When I played video on Youtube green horizontal line at regular intervals(1/4") across the screen.
                I replaced the T-Con board but the lines are still there.
                I believe this issue is from the Main Board. Before I replace the Main board, I wanted to seek advise if this is the problem from the Main board or something else?
                Thank you for the help....
                02-05-2023, 03:39 PM
              • visionbluedemon
                Help. Sony kd-65x85dj vertical lines
                by visionbluedemon
                First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                tried blocking LC lines too, but same results
                is it lcd panel issue or tcon board issue?...
                07-25-2025, 04:56 AM
