LG 4K 49SJ810V-ZA cap identify
  • kalemaroni
    • Jun 2016
    • 184
    Can anyone help identify the two circled (shorted) caps in this picture or recommend suitable values that would work?
  • lotas
    • Jan 2016
    • 4752
    • Russia
    Re: LG 4K 49SJ810V-ZA cap identify
    Remove it (most of all, one is shorting, and the second is on the same bus, connected in parallel), everything will work fine without them.
    • kalemaroni
      • Jun 2016
      • 184
      Thanks for the reply.
      I removed them both but the short is still there. I measured all the caps along the entire line and no other shorted ones. I injected voltage and the ribbons glowed warm in the thermal camera as well as the two points where I'd soldered the terminals. Any ideas what could be happening here?
      • lotas
        • Jan 2016
        • 4752
        • Russia
        It is necessary to disconnect all the loops from the T-Con and check without it, the circuit may be in the panel itself.
        • kalemaroni
          • Jun 2016
          • 184
          By the loops do you mean the 6 brown flex cables that are soldered onto the board running down from top to bottom in this pic?
          • petehall347
            • Jan 2015
            • 4439
            • United Kingdom
            ribbon cable isnt inserted straight
            • kalemaroni
              • Jun 2016
              • 184
              That's not the problem, I only put the cable back in for the picture so it was more obvious what people were looking at. Thanks though, and well observed!
              • lotas
                • Jan 2016
                • 4752
                • Russia
                No, of course, if you tear these 6 from the slats, then you can already throw out the panel, I meant these cables.
                • Diah
                  • Feb 2013
                  • 6437
                  the questions after you removed both caps. did you measure them out the circuit if they are really shorted !!!!!.... i wounder what TV problem you have make you go direct to the buffer boards ???
                  • kalemaroni
                    • Jun 2016
                    • 184
                    They were not shorted. When the flex is disconnected the circuit is still shorted. The problem is that the screen is white. When I disconnect the cable that goes to the shorted buffer board half the screen works.
                    • kalemaroni
                      • Jun 2016
                      • 184
                      Yes, I had already removed that cable. When the cable is in the whole screen is white. When I remove it half the screen works (the side that doesn't have the shorted circuit)
                      • lotas
                        • Jan 2016
                        • 4752
                        • Russia
                        Post a photo of this whole, non-working plank in good quality.
                        • Diah
                          • Feb 2013
                          • 6437
                          how about when you disconnect the good side.. did the suspected side turn white again or remain black.?
