Can anyone help identify the two circled (shorted) caps in this picture or recommend suitable values that would work?
LG 4K 49SJ810V-ZA cap identify
Tags: None
Re: LG 4K 49SJ810V-ZA cap identify
I removed them both but the short is still there. I measured all the caps along the entire line and no other shorted ones. I injected voltage and the ribbons glowed warm in the thermal camera as well as the two points where I'd soldered the terminals. Any ideas what could be happening here?Comment
They were not shorted. When the flex is disconnected the circuit is still shorted. The problem is that the screen is white. When I disconnect the cable that goes to the shorted buffer board half the screen works.Comment
Yes, I had already removed that cable. When the cable is in the whole screen is white. When I remove it half the screen works (the side that doesn't have the shorted circuit)Comment
how about when you disconnect the good side.. did the suspected side turn white again or remain black.?Comment
by reessiHello:
I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
I started on the ACER:
Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap... -
by dqtechthis is gpu area....part that i mark with red colour is short to ground....how can i check either GPU chip it self or only caps has been shorted yaa?...
by YanlebHi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
D608, good
D618 RF101L4S, good (See warning 1 below)
D619 RF101L4S, good (See warning 1 below)
D865 RF101L4S, shorted (See warning 1 below)
IC464 Inverter HA MC74HC1G14, shorted...03-09-2020, 12:00 AM -
by s_henyaHi guys,
Got this nice laptop in yesterday.
MB: GS557GS558
Previous owner dropped a screw that shorted the MB.
Removed faulty cap that got burned due to short.
Found burning hot ic
QqBUA- no information about it in google.
Any advice what is this IC?
Would be a shame to scrap this board…... -
by BalkanBoyHi,
today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
I removed coil and injected 0.7V, it draw around...09-27-2024, 12:44 PM - Loading...
