Vizio VX42L Pop then Screen blurred - LCD Problem
+ More Options
Posts
  • Quasar
    • Sep 2010
    • 132
    Re: Vizio VX42L Pop then Screen blurred - LCD Problem
    Excellent! Perhaps doing the power supply will stop the buzzing...? Or, it could be a poorly/loosely wound transformer and nothing you do will stop the buzz. Can you identify the noisy part?
    • stauffercaps
      • Sep 2010
      • 18
      Sounds like the noise is coming near these "transformers"? Hard to tell which one. See Picture!
      The TV has been on all day today, Still not convinced it is fixed completely since I had a hard time getting it to reproduce the issue this last time I disassembled the TV. I'll let it cook for awhile longer to see. Thanks.
      • Quasar
        • Sep 2010
        • 132
        I don't think there is much you can do about it. As I said, if they are poorly made, the buzzing will be more noticeable. If the power supply has caps that are on the "bad" list, I would recap it now, while you have it open. I don't think it can hurt.
        • stauffercaps
          • Sep 2010
          • 18
          Listing of the Caps on the power supply and the inverter boards.
          • Quasar
            • Sep 2010
            • 132
            Tough to respond to that list. Can't cut/paste picture.... :p
            Series seems missing on many. Rubycon is a 2 or 3 letter code from what I've seen. PX, MBZ, MCZ, etc.
            PET is the plastic used for the sleeve. "Polyethylene terephthalate (PET or PETE)" Same plastic for water bottles, soda... The number "1" inside the resin mark on plastic recyclable items.
            I'd venture that any decent manufacturer with an ESR of around .035 ohm or so would be a good choice. Good ripple handling very important too. Panasonic FC. FM may be considered overkill, but they would work too. Some times they are cheaper also.
            Nichicon HE, PW, or PM, UCC KY (already there), and KZE. UCC is not named on their caps, but has a little shield mark.
            Going to need sizes as there are quite a few under the heat sinks so post up the dimensions (D x H) in mm's. Note the max height that will fit under them.
            • stauffercaps
              • Sep 2010
              • 18
              #26
              I will update the list into a text format. I couldn't paste the table into the replies is why I uploaded the pictures.
              Are you saying the Nichicon HE, PW, or PM, UCC KY are the ones to purchase as replacements along with Panasonic FC and FM's?
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                #27
                Pour varnish into them, let dry, done. This always works for me.
                A working TV? How boring!
                • Quasar
                  • Sep 2010
                  • 132
                  #28
                  ...and KZE.
                  Any of those are suitable for use here.
                  • Dgtech
                    E. Technician
                    • Apr 2009
                    • 1462
                    • Steeler
                    #29
                    I just got done repairing one of these sets today. (Vizio VO42L)
                    I want to add a little help to someone in the future with this set.
                    After checking the two electrolytic's on both of the inverters, check these parts (See attatchment - red box) and measure resistance. There are four of them.They should read somewhere around 8.5K ohms. Sorry, I rushed through the repair and didnt write down what the part is. If they read significantly lower, then the BD9897FS chip (boxed in green) is bad and needs replaced. Replacing it is a task in itself but it can be done with the right tools.
                    Note: Without the BD9897FS chip on the board, these other four components (in red) will measure approx 10K across them. Each of those four will measure open (infinite) if they were alone off of the board. They have a 10K resistor in parallel to them. The chip is also in that circuit bringing the resistance down to 8.5K. In my case, I had one measure 63 ohms across one of the four. Changed the chip, and now it reads 8.5K.
                    Good luck!
                    • Lupo9
                      Steve
                      • Jan 2015
                      https://www.badcaps.net/forum/showthr...974#post129974
                      I removed one of the four that was shorted, Off the board it is shorted also
                      it is a DH15AL - I am unable to find it. Do you know where I can buy them?
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4984
                        • New Zealand
                        #31
                        What is this part you removed? Your link doesn't work.
                        -David VanHorn
                        • spice_disc
                          Vizio TV M50-C1 reboot cycle and static on screen
                          by spice_disc
                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                          09-08-2024, 02:37 PM
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • reformatt
                          by reformatt
                          07-31-2025, 08:37 PM
                        • smic717394
                          by smic717394
                          07-25-2024, 10:16 AM
                        • paqman
                          Vizio M60-C3 black screen
                          by paqman
                          So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
                          So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
                          03-02-2024, 04:37 PM
