RCA L42WD22 No Picture
  • mconnelly
    • 6
    #81
    Re: RCA L42WD22 No Picture
    i'm confused
    • light0070702
      • May 2014
      • 9
      • usa
      #82
      first i want to say thank you so much for everything in this thread my TV is now up and running i did get two caps from radio shack i went to the guy cause i asked him if the cap was low esr he could not answer the question the cap was blue though and looked exactly like it should be the same one but i did my research and the cap might have been blue but it should have been black the guy could not even tell me the difference between the color of the caps but anyways i put the two caps in and my TV fired right up after awhile it flickered and the speakers started screeching like crazy after i looked everything over i found that i did not have all the grounds hooked up so i tried again no screeching. so anyways i ordered the board anyways could not hurt to have a spare board. any suggestion on anything you read let me know and i want to say thank you to you all for the help
      (i stand corrected my tv is an rca l37wd12 but everything in this post is the same issue
      • Gaamcire
        • Aug 2014
        • Usa
        #83
        I am having issues with my 42 in rca tv and seeking some help. I have replaced some capacitors and one fuse. I have no picture or sound. When I plug my tv in and I power it on, one green light shows up and stays on, then an additional green comes on for approx 5 seconds then turns off. Immediately after the second green light turns off a blue light comes on for approx 3 seconds. I am out of ideas and have attached pics of my boards. Any help would be appreciated
        • Gaamcire
          • Aug 2014
          • Usa
          #84
          • Gaamcire
            • Aug 2014
            • Usa
            #85
            any help??
            • brithepi2k
              Samsung UE75TU7020k No picture, Standby blinks 2 times
              by brithepi2k
              My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
              04-23-2025, 10:05 AM
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • madan1
              DALI SUB E-12F class D, fluctuating power rail
              by madan1
              Good day everyone.
              I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
              The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
              The normal value of the positive and negative power rails is +/- 43V.
              The positive rail stays...
              10-15-2025, 10:33 AM
            • slimsoul
              Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
              by slimsoul
              Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
              I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
              I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
              The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
              03-12-2024, 03:55 AM
