LG 43LJ594V PS pulsing. TV won't go to stby
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi There!
    I just got this TV set. It won't even light up the st-by led.
    I opened the set and the PS is model LGP43DJ-17F1.
    Only 2 secondary voltages: 13,2V for main and 68V for BL
    BL capacitor gets steady 90V (but at this time the voltage is not latched onto the BL strips, so it sees it open)
    13,2V capacitors get 7,8->8v pulsing a little.
    All this both with connectors to main & BL and without them, no change
    I hace checked all diodes on board and they all test OK (on board) both in forward (0,4-0,6v) and reverse (open). Also no SMD diodes & mosfets in back side show continuity between their legs
    I can't find the schematic for this board.
    Can anyone figure out where to look first?
    Attached pics of PS board
  • edugimeno
    • May 2017
    • 581
    • Spain
    Re: LG 43LJ594V PS pulsing. TV won't go to stby
    Uh... according to the attached document, it looks like 7.8-8v is correct when TV is OFF...
    Maybe that's because this TV doesn't have a standalone 5v_stby voltage and maybe it lowers the mains voltage while off
    Does it make sense? Why is the stby led off?
    • lotas
      • Jan 2016
      • 4599
      • Russia
      LG 43LJ594V Service manual.
        • 12192
        • U.S.
        DO the first test there in your attachment, Forcing smps on with a jig.
        • edugimeno
          • May 2017
          • 581
          • Spain
          Ok I got some updates today
          I checked the PS board with the suggested method in my previously attached PDF. 3v to PWR_ON and "13v" voltage rises from 7.8V (meaning STBY in this setup) to 13V (meaning full ON).
          Then applied 3v to DRV_ON as well and got 159V on BL socket, exactly the expected voltage from specs PDF
          Also I plugged the LED strips into its socket and this voltage was ok to light up the backlight (although very blueish, so these will need replacing sooner or later)
          So I call the PS board GOOD. I put it back into the set to test again.
          Same symptom, no stby led on, still I clicked on the front panel button and tried the remote PWR_ON and nothing changed, no BL, no 13V (still 7.8v).
          So this sounds like a bad MAIN board? (attached pics from MAIN) What are my chances that I buy a new one and it works? I also tried with all the other wiring in MAIN board disconnected (SPKRs and LVDS to tcon) and nothing changed
          Is there any chance that the small board inside the remote IR sensor/push switch could be the issue? How can I test this? I don't want to pay for a new main board and have any risk on not being the issue...
          Thanks!
          • edugimeno
            • May 2017
            • 581
            • Spain
            Let me add something myself...
            Provided this PS only generates one single voltage to the main board, it is expected that the main board has several sub power supplies
            If the stby led doesn't even power up, this probably means the sub PS that provides voltage for the stby led is dead or shorted out. Does this make sense?
            Would it be easy to find out where to start to look at?
            Thanks!
            • CapLeaker
              Leaking Member
              • 8158
              Kind of. VSB is generated on the PSU. So make sure the PSU is generating VSB. That goes either directly or through a buck regulator to the main IC on the main board.. Most of the TV’s I repaired with this issue ended up with the problem being on the main IC.
              • edugimeno
                • May 2017
                • 581
                • Spain
                This PS is a bit different than other I've seen. It only has one output. This output generates either 7.8V when in Stbdy (off) to keep the IR and other stuff alive, and then switches to 13V when ON to power on everything else. I checked this switching with PS_ON hi and lo and it works perfect.
                So all goes on this single PS output.
                I can see a bunch of other dc-dc converters on the main board. Is it worth to try to diagnose them all and see if any of them is faulty?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  See if there's shorts to gnd, I've had this board with mlccs short.
                  • edugimeno
                    • May 2017
                    • 581
                    • Spain
                    Ok that seems easy to test, will check that tonight
                    • edugimeno
                      • May 2017
                      • 581
                      • Spain
                      Ok I checked the main board ok. Found no shorted caps, but I'm starting a new thread for this as the subject changed...
                      https://www.badcaps.net/forum/showthread.php?p=1238940
                      • edugimeno
                        • May 2017
                        • 581
                        • Spain
                        TV has been fixed, there was a fried choke very close to the socket from PS board, in the +13V line, that was feeding a shorted to GND capacitor.
                        All good now, thanks everyone
                        • Diah
                          • Feb 2013
                          • 6374
                          good job- the credit to @ReeceyBurger123 who pointed to same fault
                          • edugimeno
                            • May 2017
                            • 581
                            • Spain
                            Exactly, but the short was "hidden" due to a tinitiny blown choke...I was about to order a new main board for this TV. I still have to replace the led strips as they have the blue-tint-of-death... (C) LG
                            • speggio91
                              820-00165 pulsing and stuck at S5
                              by speggio91
                              Hello everyone!
                              I have this board that got slightly water damanged and it is stuck at S5 state. It pulses once every 5 seconds.
                              When connected the magsafe 2 to the bench psu, the current goes from 0.02A to 0.10A when is pulsing.
                              When using the genuine magsafe 2 charger, the light turn on and it became green and then amber. The fan is not spinning.
                              When I tried the SMC bypass mode, the fan spins a quarter every 5 seconds and the pulsing is still present every time the fan spin.
                              The pulses are present in the CPU Vcore rails on L7320 and L7310....
                              11-25-2023, 11:25 AM
                            • edugimeno
                              LG 43LJ594V main board not providing stby power
                              by edugimeno
                              I there!
                              I have this TV set that doesn't even light up the st by led. I fully checked the PS board and this one is fine, it provides 8.9V when Stdby and 13V when ON (forces by DRV_ON pin according to service document)
                              So I checked the main board and it is not able to even light up the stdby led and of course it won't obbey to ON button or remote signals
                              I checked all caps on board, none of them is shorted. I took some voltages at those caps, some of them have 8.9v on one side, some don't have any voltage. I see some coils and smalls IC's near banks of SMD...
                              05-14-2023, 12:41 PM
                            • Goldwing1973
                              Sonos Play 1 pulsing power supply
                              by Goldwing1973
                              I'm rather new to repairing electronics, i do know the basics of most components but never actually repaired a PCB, but i want to change that.
                              So, i bought a faulty Sonos Play 1 speaker with the intention of finding the fault, and replace the damaged part.
                              Well, i did find the fault, i replaced parts that i thought caused the problem, but no-go.
                              The problem is a pulsing power supply, when i connect the mains to the board and hook up my thermal cam i see R306,307 and 308 getting warm, but i assume that's normal.
                              But, whats is not normal is the pulsing of resistor...
                              07-04-2025, 12:59 PM
                            • MobileXT
                              MBA 13 2020 820-01958 Pulsing 5V_G3S
                              by MobileXT
                              I have a MBA 13" 2020 820-01958 that was pulsing on 5V_G3S and P1V8_G3S power Rail. Also pulsing on the enabled PIN on U7650 PIN4. Pulsing on P5VG3S_EN R7613 PIN 1. Anybody has the same problem? any idea was causing the power rail pulsing. I don't see shorted on the board. Thanks
                              09-13-2022, 08:34 PM
                            • ronyan
                              Macbook Air 820-00165 board power pulsing twice and missing PM_SLP_S4_L
                              by ronyan
                              I have a 820-00165 board that is power pulsing twice going from drawing 34mA up to ~350mA then back down to 34. No fan spin. It is missing the PM_SLP_S4_L signal. As I have no previous experience with this particular problem, I've been measuring a lot and have already replaced U1900 and U1950. I've also replaced R5513 near the SMC that looked corroded. The behavior of the power pulsing twice has not changed.
                              I've watched some of Louis' youtube videos on the issue and have checked the SPI resistors for continuity and they are good, probe points are also excellent, no signs of corrosion....
                              02-11-2023, 05:30 PM
