1986 Fisher television B+ Low
  • drunkendwarf
    • Apr 2023
    • 7
    Hi guys, i have a 1986 Fisher PC420 television. Chassis #A7R-42000
    it works but has no picture width and some barrel distortion. i narrowed it down to low B+ 89volts. service manual says it should be 111volts.
    it uses these Sanyo hybrid IC chips for error detection and drive that are discontinued and i cannot find anywhere. i found one post regarding a Sanyo TV with same symptoms and the resolution was the error detect module.
    Part # JU0161 and JU0148
    i'm now looking at bypassing that error detect to the optocoupler circuit somehow with my own. i don't have the skills to design a circuit and don't know where to start.
    at 89VDC the optocoupler diode measured from pin 1 and 2 is 0.963 volts
    i'll attach pics of the IC's and schematics. any help is appreciated.
    thanks
  • R_J
    • 9555
    Re: 1986 Fisher television B+ Low
    Have you tried replacing the electrolytics (C014 etc.) in that circuit first instead of going after those modules?
    • drunkendwarf
      • Apr 2023
      • 7
      Yes, I apologize. I forgot to mention I replaced all the electrolytic caps.
      • R_J
        • 9555
        Do you have the voltages from the Error Drive Unit? What are the voltages compared to the schematic, that might give a clue to where the problem is.
        • drunkendwarf
          • Apr 2023
          • 7
          on the error drive i got the following on what i measured.
          Error Drive Measured. Schematic
          Pin13 0.650v 0.70v
          Pin12 18.22v 23v
          Pin8 19.80v 19v
          Pin6 1.286v 1.6v
          Pin4 -1.401v -1.7v
          Pin3 1.294v 2.1v
          Pin2 0.612v 0.3v
          on the Error Detect.
          Measured Schematic
          Pin10 88.9v 111v
          Pin9 88.9v 111v
          Pin 7 7.17v 6.0v
          Pin 1 33.3v 40v
          on the switching IC Q002
          159v measured schematic says 150v
          i've also removed the main resistor that drives the flyback transformer and the B+ went to 107volts. i was told the regulator still isn't working as it should have been around 130volts
          • R_J
            • 9555
            Try replacing the optocoupler, the voltages are close so something is off value but not totally bad. The switching power supply is working so hopefully it is not a fault of one of the modules. Can you post the complete schematic?
            With the main resistor removed that supplies the flyback does not totally disconnect the power supply output as it looks like it also connected to R477 and that circuit?
            • drunkendwarf
              • Apr 2023
              • 7
              i did replace the optocoupler with a tlp621 that i had on hand with no change.
              attached the power supply schematic.
              • drunkendwarf
                • Apr 2023
                • 7
                it is the JU0161 Error detect module. i substituted some zener's and resistors and the B+ came up to 111volts and the picture is perfect.
                now if i can only find one of the replacement modules.
                • R_J
                  • 9555
                  Just a couple ideas:
                  Can you isolate the faulty component on the module, using heat or cold spray?
                  Maybe you can use something like a SE110N error amp ic to drive the optocoupler, Sony chassis ba4d uses a SE135N-LF12 to drive the opto to regulate it's 135v
                  • drunkendwarf
                    • Apr 2023
                    • 7
                    i tested the SOT23 Transistor and zener diode and seem okay. the problem is the thin film resistors on it. the manual doesn't specify the resistance.
                    i have a tv shop looking for one.
                    thanks
                    • cj_reha
                      Mystery 80s Sanyo cap - perhaps polymer?
                      by cj_reha
                      Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                      01-06-2023, 09:24 AM
                    • mojos911
                      Fisher and Paykel 10 kg top-load washing machine LED identification
                      by mojos911
                      I'm looking for a replacement for the red LEDs used in a Fisher & Paykel 10 kg top-load washing machine. Each LED is about 6 mm long, mounts flush to the PCB with side tabs, and measures around 1.7 V forward voltage in diode-test mode. The marking on the body is “3A56,” but I can't find any matches for that in part searches. I've attached photos to show the shape and mounting style.
                      If anyone has sourced an equivalent or knows a suitable replacement, I'd really appreciate your input. Thanks in advance for the help!...
                      01-17-2025, 06:54 PM
                    • toddw65
                      Sanyo DP5834 - Gray Screen
                      by toddw65
                      Hey All,
                      I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
                      Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
                      Thanks,...
                      10-31-2024, 10:37 AM
                    • Jackching
                      Intel PC hooked to X90L television picture cut-off
                      by Jackching
                      I have my Intel PC hooked to my Sony X90L television and each time the power is cycled on the tv, the bottom of the PC screen gets cut-off. Only half of the taskbar shows until i go into display settings and cycle the display size and it'll work fine until the next time I power off the tv. I updated the drivers. The graphics is UHD 630.
                      10-27-2024, 11:43 AM
                    • jm1234
                      optocoupler? B3PBE0000060
                      by jm1234
                      I'm troubleshooting SN board of Panasonic plasma TV and I'm curious about a component that looks like an optocoupler, it has 5 legs though. I tried to check between legs 1-2, but no diode junction there, it's open. So either that is not a diode there or it's burnt.
                      For future searches, the part num is B3PBE0000060, the label on the component says 9157 and N219.
                      Any idea?
                      05-24-2024, 12:51 AM
