Vizio M70-C3 diagnosis
  • objext
    • Apr 2023
    • 16
    Hi all, I have an M70-C3 Vizio that won't power on. I do get power/standby LED and optical output operation. I don't seem to have backlighting or display image, or sound.
    I have negligible voltage (0.001-0.003V) at T CON_ON and both 12V T CON pins.
    I have 12V on both +12VS pins.
    I have 33.xxV on 24V1 pins.
    TV was working before a thunderstorm, but I'm not 100% sure that's why it quit. I tried to record how the standby LED functions in the attached list. What should I look at? Power supply caps appear okay. Thanks!
    • 12276
    • U.S.
    Re: Vizio M70-C3 diagnosis
    Picture isn't clear enough to read the legend beside the connectors.
    • objext
      • Apr 2023
      • 16
      How about these
        • 12276
        • U.S.
        How is the tcon fuse? see if there's continuity.
          • 12276
          • U.S.
          Maybe try a firmware update thru usb.
            • 12276
            • U.S.
            Guess they want you to put your serial # in, then just follow as directed, sometimes a storm will mess up the firmware, other times a storm will go thru and fry some thing/s, site there: https://support.vizio.com/s/firmware...language=en_US
            • objext
              • Apr 2023
              • 16
              Tcon fuse checks out ok
              • objext
                • Apr 2023
                • 16
                Hate to sound helpless, but their page doesn't work. After I enter the s/n (LFTRSYAR3002382), it takes me to a page that says
                Most Recent Firmware Version: 1.5.16
                Please click here for more information regarding this firmware.
                ...but when you click for more information it takes you to an invalid page.
                  • 12276
                  • U.S.
                  Yep, I get the same, wonder if they took it off their site, maybe try contacting them and see if they can send it to you or point you to where it is, might have to get a supervisor if they say they don't have it or they start to be difficult.
                  • objext
                    • Apr 2023
                    • 16
                    Yep, I get the same, wonder if they took it of their site, maybe try contacting them and see if they can send it to you or point you to where it is, might have to get a supervisor if they say they don't have it or they start to be difficult.
                    Updating the firmware doesn't require anything to be seen on-screen?
                      • 12276
                      • U.S.
                      I don't think it does for this model.
                      • objext
                        • Apr 2023
                        • 16
                        Also nothing on this tcon connector. I do get PS-ON signal, etc. Power supply seems to be working (?). Have tried pressing on main board heatsink, but no change.
                          • 12276
                          • U.S.
                          Can you post a picture of the whole back, as to see how everything is connected and a good clear one of the mainboard, also give it a good smell test, see if you can detect any faint burnt smells or see any small burnt traces etc.
                          • objext
                            • Apr 2023
                            • 16
                            No smell of burning
                              • 12276
                              • U.S.
                              Unhook cable from powerboard to mainboard, check voltage at each pin of CN201, report readings, if anyone has any ideas on what to test or whatever, lets hear it, appears to be a tough one.
                              • objext
                                • Apr 2023
                                • 16
                                0
                                4
                                0
                                0.43
                                0
                                0
                                0
                                12.7
                                12.7
                                0
                                0
                                0
                                0
                                0
                                0
                                This doesn't surprise me because it can't be powered on without the main board.
                                • howardc64
                                  • Jun 2017
                                  • 636
                                  Probably the classical ~2015 Vizio BGA solder failure. While this main board has a better heatsink with a heat transfer pipe to the rear chassis, the symptoms sound quite classic to these common Vizio BGA solder ball failures. Although other Vizios with the BGA failure often exhibit blinking standby LED lights thats not present here.
                                  Here is the pic of M70-C3 main with heat sink removed (copied from ebay)
                                  Here is a post with likely same Vizio BGAs with heat sink removed (memory layout orientation slightly different but probably the same BGAs). OP in this thread did the typical heat reflow and got the TV to boot with display in post #11.
                                  https://www.badcaps.net/forum/showpo...72&postcount=3
                                  Here is badcap search result for "m43. Probably all with this typical Vizio BGA solder failure problem. Lots of ~2015 era Vizios used these BGAs and have solder failure problems. Likely from using older (cheaper) hotter chip fab while pushing it with more smart TV functions (makes it hotter) Combined with the problematic lead-free BGA solder balls results in balls cracking over time and failing. AMD/nVidia GPUs first encountered this in the late 2000s.
                                  https://www.badcaps.net/forum/search...rchid=33613311
                                  You can try to heat the heatsink with hairdryer for awhile and see if TV boots.
                                  I believe the only long lasting fix is using a proper BGA reflow station : Remove chip, reball (typically leaded balls), resolder. Short cuts like heat gun, hot air station, oven bake will not last very long
                                  • objext
                                    • Apr 2023
                                    • 16
                                    I did try hot air but without removing the heatsink. Will the studs pop out without pulling the board? Otherwise, sounds like a main board issue, yeah?
                                      • 12276
                                      • U.S.
                                      Was trying to verify the powerboard, but I thing Howardc64 is on the money, probably need a new chip or reworked with leaded balls.
                                        • 12276
                                        • U.S.
                                        You can send it to Nick's, he will fix it without robbing you: https://www.youtube.com/watch?v=G1Rh6Snf94g
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • corrize
                                          Where to find a very small fpc connector 0.3mm between 2 pins ?
                                          by corrize
                                          Hello, I search this connector (oxydated).
                                          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                          Do you know how to find this connector please ? What is the exact name for find it ?
                                          08-06-2024, 05:25 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
